how is the mos factor or r-factor calculated
rabeder
hi,
my question is how i can calculate the mos value.
is there a directly correspondence between icpif and mos?
or is the correspondence between the r-factor and mos ?
here is a output of the routers sla agent:
MPLSRBGORTR01#sh ip sla monitor collection-statistics 20192001
Entry number: 20192001
Start Time Index: 09:36:00.952 MES Mon Aug 21 2006
Number of successful operations: 16
Number of operations over threshold: 0
Number of failed operations due to a Disconnect: 0
Number of failed operations due to a Timeout: 0
Number of failed operations due to a Busy: 0
Number of failed operations due to a No Connection: 0
Number of failed operations due to an Internal Error: 0
Number of failed operations due to a Sequence Error: 0
Number of failed operations due to a Verify Error: 0
Voice Scores:
MinOfICPIF: 11 MaxOfICPIF: 11 MinOfMOS: 4.06 MaxOfMOS: 4.06
RTT Values (milliseconds):
NumOfRTT: 16000 RTTAvg: 4 RTTMin: 2 RTTMax: 26
RTTSum: 67593 RTTSum2: 304199
Packet Loss Values:
PacketLossSD: 0 PacketLossDS: 0
PacketOutOfSequence: 0 PacketMIA: 0 PacketLateArrival: 0
InternalError: 0 Busies: 0 PacketSkipped: 0
Jitter Values (milliseconds):
MinOfPositivesSD: 1 MaxOfPositivesSD: 21
NumOfPositivesSD: 1528 SumOfPositivesSD: 3389 Sum2PositivesSD: 11883
MinOfNegativesSD: 1 MaxOfNegativesSD: 16
NumOfNegativesSD: 1516 SumOfNegativesSD: 3369 Sum2NegativesSD: 11631
MinOfPositivesDS: 1 MaxOfPositivesDS: 4
NumOfPositivesDS: 1201 SumOfPositivesDS: 1532 Sum2PositivesDS: 2352
MinOfNegativesDS: 1 MaxOfNegativesDS: 4
NumOfNegativesDS: 1190 SumOfNegativesDS: 1531 Sum2NegativesDS: 2383
Jitter Avg: 1 JitterSD Avg: 2 JitterDS Avg: 1
Interarrival jitterout: 0 Interarrival jitterin: 0
One Way Values (milliseconds):
NumOfOW: 16000
OWMinSD: 1 OWMaxSD: 23 OWSumSD: 34811 OWSum2SD: 92619
OWMinDS: 1 OWMaxDS: 6 OWSumDS: 32782 OWSum2DS: 69572
OWAvgSD: 2 OWAvgDS: 2
Start Time Index: 08:36:00.948 MES Mon Aug 21 2006
Number of successful operations: 30
Voice Scores:
NumOfRTT: 30000 RTTAvg: 4 RTTMin: 2 RTTMax: 25
RTTSum: 126600 RTTSum2: 565324
Packet Loss Values:
MinOfPositivesSD: 1 MaxOfPositivesSD: 22
NumOfPositivesSD: 2654 SumOfPositivesSD: 5749 Sum2PositivesSD: 18535
MinOfNegativesSD: 1 MaxOfNegativesSD: 20
NumOfNegativesSD: 2651 SumOfNegativesSD: 5736 Sum2NegativesSD: 18328
MinOfPositivesDS: 1 MaxOfPositivesDS: 5
NumOfPositivesDS: 5133 SumOfPositivesDS: 5601 Sum2PositivesDS: 6867
MinOfNegativesDS: 1 MaxOfNegativesDS: 7
NumOfNegativesDS: 5151 SumOfNegativesDS: 5599 Sum2NegativesDS: 6815
NumOfOW: 30000
OWMinSD: 0 OWMaxSD: 23 OWSumSD: 52523 OWSum2SD: 118923
OWMinDS: 1 OWMaxDS: 12 OWSumDS: 74077 OWSum2DS: 193055
OWAvgSD: 1 OWAvgDS: 2
thanks for answer
gpulos
Level 8
Level 8
with IOS 12.3(14)T and higher use this command to get MOS and ICIPF scores:
show ip sla monitor collection-statistics (as you've used above); view the output as shown below: (excerpt from your output)
Voice Scores:
(any value of zero means that score was not generated; your MOS score for this is 4.06)
ICPIF corresponds to the score as set by the dialPeer that sent the call. (cisco specific i believe; calculatedPlanningImpairmentFactor)
MOS corresponds to the industry standard of voice quality measurement at the destination end and is expressed as a number from 1 (lowestQuality) to 5 (highestQuality)
you could say that there is correspondence between R-factor and MOS, but not R-factor and ICPIF.
ok, thanks f answer - sounds logical, but:
if you say my mos corresponds to r-factor - can i calculate the r-factor from the output above?
(sh ip sla collection-stat)
or are the parameters to get the r-factor not in the output
(only for interrest)
