Router 1841
lalit0005
we have one query with 1841 router.one customer is asking for router over which two different line,one for data and other for voice,terminats.so i want to know the technology behind this.
sachinraja
Level 9
Level 9
Hello Lalit,
1841 will not support voice... so, if you want both data and voice, you might have to look atleast at a 2800 router... there are a lot of voice cards that the 2800 supports.. your statement can mean that the customer wants a pure data line , through which the traffic flows, and can also need a voice port, which can be used for setting up some VOIP infrastructure... You can probably question back the customer and get his exact voice requirement, since for each requirement there can be a solution or a router module....
Hope this helps.. all the best...
Raj
sachinraja
Level 9
Level 9
Hello Lalit,
Raj
aryan1980
how about voip
