Router 1941w
rnabibaksh
Good Afternoon.
currently I have the 1861 Router with Voice Bundle/SRST.  Can I replace the 1861 Routers with a 1941W router and still have Voice Bundle/SRST?
Ryzwan Nabi
Philip D'Ath
The 1941 (or 1941W) does not have voice support.  You need to up go to a 2900 series router, such as a 2901.
I would probably started by looking at a voice bundle like CISCO2901-V/K9 (or if you need a firewall/vpn, etc CISCO2901-VSEC/K9).  This is the cheapest way of buying them.
https://supportforums.cisco.com/discussion/11341201/cisco-1941-router-support-voice
Then buy a separate access points - the standalone units are much better.  Examples are the Cisco 1830 or 1850:
http://www.cisco.com/c/en/us/products/wireless/buyers-guide.html#~indoorac-wave2
If you wanted to go to the latest platform you could also consider a 4000 series router, like the 4321:
http://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/models-comparison.html
The voice bundle you would probably be most interested in would be ISR4321-V/K9.  Note that these routers run the newer IOS-XE.
So the 1941 above will do everything the 1861 does, and the config will be close to a "cut and paste" job.  Because the 4321 runs IOS-XE (instead of IOS) quite a few things work differently, or are plain missing.  Don't ask me which - I usually find out the hard way.
Whatever
