04-20-2016 10:03 AM - edited 03-05-2019 03:51 AM
This is just for the sake of discussion.
I have a border router that is running EIGRP and eBGP. I'm doing two-way redistribution like below:
router eigrp 1
redistribute bgp 64801 metric 1500 1 255 1 1500
router bgp 64801
redistribute eigrp 1
When using the command "show ip bgp neighbor a.b.c.d advertised-routes", I see that the routes learned from eBGP neighbor (foreign routes) were not being advertised. This is a normal and expected behavior. But the dumb question is:
1) Since we're redistributing BGP routes into EIGRP, EIGRP has those foreign routes.
2) At the meantime, we're redistributing EIGRP routes into BGP (including the foreign routes). Why BGP is not advertising the foreign routes out to eBGP peer?
Again, just for the sake of discussion. Thanks!
Solved! Go to Solution.
04-20-2016 01:14 PM
routes are only redistributed when they are in the routing-table. The route is learned via eBGP and a routing-table entry is created with an AD of 20. This route is then redistributed into EIGRP but no EIGRP route will be installed locally because EIGRP has a higher AD than eBGP and, even more important, self-orinated external routes are ignored for local route calculations. So a redistribution back into BGP cannot take place even though it is in the EIGRP topology table - it is required to be present in the routing table.
Rolf
04-20-2016 12:31 PM
Here are the output from the router. 20.20.20.0/24 is learned from eBGP. The question is - why 20.20.20.0/24 was not being advertised back to eBGP peers?
R2#sh ip eigrp topology
EIGRP-IPv4 Topology Table for AS(1)/ID(172.255.1.1)
Codes: P - Passive, A - Active, U - Update, Q - Query, R - Reply,
r - reply Status, s - sia Status
P 10.255.1.0/30, 1 successors, FD is 281600
via Connected, Ethernet0/0
P 20.255.1.0/30, 1 successors, FD is 1706752, tag is 64002
via Redistributed (1706752/0)
P 20.20.20.0/24, 1 successors, FD is 1706752, tag is 64002
P 172.255.1.0/30, 1 successors, FD is 281600
via Connected, Ethernet1/1
P 10.10.10.0/24, 1 successors, FD is 409600
via 10.255.1.2 (409600/128256), Ethernet0/0
R2#
R2#sh ip bgp
BGP table version is 15, local router ID is 172.255.1.1
Status codes: s suppressed, d damped, h history, * valid, > best, i - internal,
r RIB-failure, S Stale, m multipath, b backup-path, f RT-Filter,
x best-external, a additional-path, c RIB-compressed,
Origin codes: i - IGP, e - EGP, ? - incomplete
RPKI validation codes: V valid, I invalid, N Not found
Network Next Hop Metric LocPrf Weight Path
*> 10.10.10.0/24 10.255.1.2 409600 32768 ?
*> 10.255.1.0/30 0.0.0.0 0 32768 ?
*> 20.20.20.0/24 172.255.1.2 409600 0 64002 ?
*> 20.255.1.0/30 172.255.1.2 0 0 64002 ?
*> 172.255.1.0/30 0.0.0.0 0 32768 ?
* 172.255.1.2 0 0 64002 ?
R2#sh ip bgp nei 172.255.1.2 advertised-routes
Total number of prefixes 3
R2#
04-20-2016 01:14 PM
Rolf
