Showing results forĀ
Search instead forĀ
Did you mean:Ā
Router 4221 WAN failed ping to external router
Hi everyone,
I work on a cisco router 4221.
I enable the WebUI and try to configure the WAN GigabitEthernet 0/0/0.
I configure it as:
  • Admin Status UP
  • Port Fast disable
  • VRF None
  • Configure as WAN
  • Primary WAN
  • PPPoe Disabled
  • IP Options IPV4
  • IPv4 Type DHCP
  • NAT Enabled
  • OSPF None
I can ping ISP
I can ping DNS Server
I can't ping Internet
Thank you so much
27 Replies 27
balaji.bandi
Do you have Static Route to ISP ?
Loging to device using SSH and post ( show run ) output here ?
also try from # ping 8.8.8.8 ?
BB
Hi man,
I can ping ISP and DNS server but not Internet
Configuration:
Cisco#show run
Building configuration...
Current configuration : 6408 bytes
! Last configuration change at 06:34:18 UTC Tue Apr 27 2021
version 17.3
service call-home
platform qfp utilization monitor load 80
platform punt-keepalive disable-kernel-core
hostname Cisco
boot-start-marker
boot-end-marker
enable password cisco
no aaa new-model
ip dhcp pool WEBUIPool
network 192.168.1.0 255.255.255.0
default-router 192.168.1.1
login on-success log
subscriber templating
no device-tracking logging theft
crypto pki trustpoint TP-self-signed-634987232
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-634987232
revocation-check none
rsakeypair TP-self-signed-634987232
crypto pki trustpoint SLA-TrustPoint
enrollment pkcs12
revocation-check crl
crypto pki certificate chain TP-self-signed-634987232
certificate self-signed 01
quit
crypto pki certificate chain SLA-TrustPoint
certificate ca 01
quit
license udi pid ISR4221/K9 sn FGL2506L4YM
memory free low-watermark processor 69247
diagnostic bootup level minimal
username webui privilege 15 password 0 cisco
username cisco privilege 15 secret 9 $9$Pr9t5rdqO0WzN.$wwaol33yRo3hTt8g4TbdzIGHxe2Z3Ik5/uSe1iE2e/A
redundancy
mode none
interface GigabitEthernet0/0/0
description WAN
ip address dhcp hostname 10.10.1.1
ip nat outside
negotiation auto
spanning-tree portfast disable
interface GigabitEthernet0/0/1
negotiation auto
interface Dialer1
no ip address
ip mtu 1452
interface Dialer2
ip address dhcp
ip mtu 1452
ip http server
ip http authentication local
ip http secure-server
ip forward-protocol nd
ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
ip route 0.0.0.0 0.0.0.0 GigabitEthernet0/0/0
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
route-map track-primary-if permit 1
match ip address 197
set interface GigabitEthernet0/0/0
control-plane
line con 0
transport input none
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
length 0
transport input ssh
call-home
! If contact email address in call-home is configured as sch-smart-licensing@cisco.com
! the email address configured in Cisco Smart License Portal will be used as contact email address to send SCH notifications.
contact-email-addr sch-smart-licensing@cisco.com
profile "CiscoTAC-1"
active
destination transport-method http
end
Thank you so much for the support
add the lines marked in bold to your configuration:
version 17.3
service call-home
hostname Cisco
boot-start-marker
boot-end-marker
no aaa new-model
enrollment pkcs12
quit
certificate ca 01
quit
redundancy
mode none
description WAN
ip nat outside
negotiation auto
--> ip nat inside
negotiation auto
interface Dialer1
no ip address
ip mtu 1452
interface Dialer2
ip address dhcp
ip mtu 1452
ip http server
--> access-list 197 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
length 0
transport input ssh
call-home
active
end
Thank you so much,
I try it but it doesn't works
This is my new configuration:
Cisco#show run
! Last configuration change at 08:03:48 UTC Tue Apr 27 2021
version 17.3
service call-home
hostname Cisco
boot-start-marker
boot-end-marker
no aaa new-model
enrollment pkcs12
quit
certificate ca 01
quit
redundancy
mode none
description WAN
ip nat outside
negotiation auto
negotiation auto
interface Dialer1
no ip address
ip mtu 1452
interface Dialer2
ip address dhcp
ip mtu 1452
ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
length 0
transport input ssh
call-home
active
end
the 'new' configuration is the same as the old one. Make sure the new one looks exactly like below, with the two lines marked in bold added:
version 17.3
service call-home
hostname Cisco
boot-start-marker
boot-end-marker
no aaa new-model
enrollment pkcs12
quit
certificate ca 01
quit
redundancy
mode none
description WAN
ip nat outside
negotiation auto
--> ip nat inside
negotiation auto
interface Dialer1
no ip address
ip mtu 1452
interface Dialer2
ip address dhcp
ip mtu 1452
ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
length 0
transport input ssh
call-home
active
end
Yes, it's right now.
I can see the blod line in show run but it doesn't work yet
I can't ping 8.8.8.8 from router
post the running configuration again with the changes you have made.
Yes of sure:
Router#show run
*Apr 27 12:58:44.875: %SYS-6-PRIVCFG_ENCRYPT_SUCCESS: Successfully encrypted private config file
Current configuration : 6167 bytes
! Last configuration change at 12:58:30 UTC Tue Apr 27 2021 by cisco
version 17.3
service config
! Call-home is enabled by Smart-Licensing.
service call-home
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
enrollment pkcs12
quit
certificate ca 01
quit
username cisco privilege 15 secret 9 $9$aVW7qHlEHAO27U$iSXww62GxWz42gNMBewMecUZlkLKHRoY8q6VHy/E8p6
redundancy
mode none
ip dhcp client client-id ascii FGL2506L4YM
ip address dhcp
negotiation auto
ip nat inside
negotiation auto
ip http server
ip http client source-interface GigabitEthernet0/0/0
ip access-list extended 197
10 permit ip 192.168.1.0 0.0.0.255 any
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input ssh
call-home
active
end
you keep changing things around, the config you posted is still incorrect. I don't know how to solve this...are you using the WebUI or the command line ?
Either way, make sure the config looks exactly (line by line) like the one below:
version 17.3
service call-home
hostname Cisco
boot-start-marker
boot-end-marker
no aaa new-model
enrollment pkcs12
quit
certificate ca 01
quit
redundancy
mode none
description WAN
ip nat outside
negotiation auto
--> ip nat inside
negotiation auto
interface Dialer1
no ip address
ip mtu 1452
interface Dialer2
ip address dhcp
ip mtu 1452
ip http server
control-plane
line con 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
length 0
transport input ssh
call-home
active
end
Thank you for the patience Georg,
I reset the configuration.
I wanted to use also WebUI but lateral menu of interface many time is blank and I don't know why.
I tried to clean cache, change browser, but nothing.
These are the lines that now I write into CLI:
enable
configure terminal
dns-server 8.8.8.8
username cisco privilege 15 algorithm-type scrypt secret cisco
interface gig 0/0/1
ip nat inside
exit
interface gig 0/0/0
ip nat outside
access-list 197 permit 192.168.1.0 0.0.0.255 any
And this is the actually show run:
Router#show run
Current configuration : 6476 bytes
! Last configuration change at 06:51:19 UTC Wed Apr 28 2021
version 17.3
service config
service call-home
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
enrollment pkcs12
quit
certificate ca 01
quit
username cisco privilege 15 secret 9 $9$kXPddDSAmBHxh.$PRm3l3hE.W/YnOhCLYVgJ/XXBKY/xRsom0eehYHPzkQ
username admin privilege 15 secret 9 $9$NLuAcsG9pVZdIk$z9oxopInQOA/FnlXM.QsNACsaxP8fX2hTVa7SCygsSg
redundancy
mode none
ip address dhcp
ip nat outside
negotiation auto
ip nat inside
negotiation auto
ip http server
control-plane
line con 0
exec-timeout 0 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input ssh
call-home
active
end
It doesn't works
below suggestions make changes and test it.
ip nat inside
negotiation auto
I do not see any Access List matching with 197
I willl make simple - ( You do not have 2 Linkls right, you have only 1 Path to Go out)
access-list 10 permit ip 192.168.1.0 0.0.0.255 any
no ip nat inside source route-map track-primary-if interface GigabitEthernet0/0/0 overload
ip nat inside source  list 10 interface GigabitEthernet0/0/0 overload
Make sure DNS also configured :
dns-server 8.8.8.8
BB
Thank you man,
I have a problem with "access-list 10 permit ip 192.168.1.0 0.0.0.255 any" (error, the arrow goes to "ip" word)
it doesn't work
This is my last config:
Router#show run
Current configuration : 6177 bytes
! Last configuration change at 09:49:12 UTC Tue Apr 27 2021
version 17.3
service config
service call-home
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
enrollment pkcs12
quit
certificate ca 01
quit
username cisco privilege 15 secret 9 $9$Z0osySJK7XiqGU$3dOswvYh.calwl2Rcp4sx5HO35kPSRFECuIC7CDbXQE
redundancy
mode none
ip address dhcp
negotiation auto
ip nat inside
negotiation auto
ip http server
control-plane
line con 0
exec-timeout 0 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input ssh
call-home
active
end
I gave the wrong syntax :
here is correct one :
access-list 10 permit 192.168.1.0 0.0.0.255
BB
Ok, I try it, now it is correct
But it doesn't work, I can't ping 8.8.8.8 from router
This is my last configuration:
Router#show run
Current configuration : 6339 bytes
! Last configuration change at 10:37:06 UTC Tue Apr 27 2021
version 17.3
service config
service call-home
hostname Router
boot-start-marker
boot-end-marker
no aaa new-model
dns-server 8.8.8.8
enrollment pkcs12
quit
certificate ca 01
quit
redundancy
mode none
ip address dhcp
negotiation auto
ip nat inside
negotiation auto
ip http server
ip nat inside source list 197 interface GigabitEthernet0/0/0 overload
ip access-list standard 10
control-plane
line con 0
exec-timeout 0 0
stopbits 1
line aux 0
stopbits 1
line vty 0 4
login
transport input ssh
call-home
active
end
