Router 7609 configuration problem
I need someone I sign off this configuration:
S764AIK9-12233SRB
MEM-RSP720-CF512M
PWR-4000-DC
WS-X6724-SFP
CWDM-SFP-1530=
CWDM-SFP-1550=
The SFP CWDM are compatible with this configuration?
I can put the SFP CWDM in the module WS-X6724-SFP and in the two slot of the supervisor?
Edison Ortiz
I see this matrix,
but from datasheet of WS-X6724-SFP this compatibility there isn't.
Also from the matrix table I see that the WS-SUP720 supports CWDM SFP, but my RSP720-3C supports it?
Thank for your support.
I can't find any notes on supported SFPs for the RSP720-3C per its documentation:
http://www.cisco.com/en/US/prod/collateral/routers/ps368/product_data_sheet0900aecd8057f3b6.html
I will assume is indeed supported but you can always confirm with your Cisco Sales Rep.
HTH,
__
Edison.
Thank you, I will do so.
By
