Router Access Problem ????
afzaalq007
I have configure a router at last i enable AAA on the router and the also enable following services
aaa new-model
aaa authorization exec default local
service timestamps debug uptime
service timestamps log datetime localtime
service password-encryption
service udp-small-servers
service tcp-small-servers
and after that i am unable to access router via console
plz ckh also line setting
line con 0
exec-timeout 0 0
password xxx
line aux 0
transport input all
line vty 0 4
password xxx
and the Messege i am getting when i connect console
% Authorization failed.
XXXX con0 is now available
Press RETURN to get started.
zerozerotito
hi Afzaal,
i think u should define a username (cuz it seems you wanna use local authentication)
You can use the following syntax to define a local user...
Router(config)# username user1 password password1
Rgrds.. Please Rate all Posts
I think we need authentication when enable authorization. Please check below doc. and search RADIUS Authentication Examples :
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7a8.html
Hope this helps.
desai.jaideep
Level 5
Level 5
I believe you need to define "login" before giving the password.
(1)Bypass the router config(NVRAM)
(2)The on con0 give.
Router(config-line)#login
Router(config-line)#password
JD
JD
In the situation described in the original post it is not necessary to specify login on the console. With aaa new-model login is automatically assumed for the console. When you configure aaa new-model several things about the console and the vty change and the treatment of "login" is one of the things that changes.
I think we need to recognize that the original post included the error message which indicated that it is an authorization error and not an authentication error. But with no authentication specified it will be hard for authorization to work. So I agree that part of the solution is to secify authentication local and to configure at least one user ID and password.
Rick
Rick
