Router ACL for outside Interface: Block inbound traffic
Jay Matrona
On Friday we are cutting over to a new datacenter so, I need to block all inbound traffic from customers but allow the IPs from two locations that will need access during this shutdown.  One of these locations are already connected via a site to site tunnel.  My question is, what does my ACL need to include to block all inbound with the exception of one IP and could the ACL impact the connectivity via IPSec tunnel in any way, or is it exempt as long as the tunnel is up?
access-list 1 permit tcp host 111.222.333.444 any
access-list 1 deny ip any any
Then, do I apply it to both outside interfaces?  (we have two loadbalanced circuits using 2 interfaces)
Thanks!
Richard Burts
Jay
You have not given much information about your environment so our ability to really give helpful answers is limited. But I offer these observations and partial answers.
- to limit access you would usually use an inbound access list on the outside interface. There may be factors that point to a different approach but we do not know if any apply for your situation.
- some people might also use an outbound access list to control access but the inbound list is more important.
- if the VPN tunnel comes in on one of those outside interfaces then the access list would impact it. So you would need to permit VPN traffic.
- access list 1 would be a standard access list which can check only a single address field. To get the ability to do ip any any you would need an extended access list perhaps access list 101
Rick
Rick
Sorry for the lack of info and thanks for the response.  I want to apply this to both outside interfaces on the edge router.
If I do that, no traffic gets into the production environment.  It sounds like I need to create an ACL permitting all IPs including those using the tunnel and then a deny all statement at the end.  Does this sound correct?  Did I have the form correct above?
Hi Jay,
That will do good for your scenario. I have done the same on my wan interface like below.
ip access-list extended Outside_access
permit ip 125.63.193.0 0.0.0.15 host 193.114.18.5
permit ip 85.218.151.0 0.0.0.255 host 193.114.18.5
permit ip host 150.101.196.135 host 193.114.18.5
permit ip host 125.7.90.33 host 193.114.18.5
permit ip host 125.7.90.37 host 193.114.18.5
deny ip any any
int GigabitEthernet0/0
ip access-group Outside_access in
But you need to make sure while defining the rules because you need to allow all the necessary IP's (like your remote tunnel IP's and required subnets.
Please rate the helpfull posts.
Naidu.
