4500 EIGRP stub problem
ktwaddell
Morning All
I have 2 4506's running the same IOS 12.2(31)SG and i know I can only run these in stub mode, but my problem is on a reboot they loose some config everytime
goes from
eigrp stub connected redistributed
to
so on reboot I have to stick redisributed on to get the static routes out into the network.
Is there a IOS out there that fixes this issue or any other suggestions?
Kevin
9 Replies 9
ktwaddell
Morning chaps
Anyone out there that can help?
just need to know if there is a fix for using eigrp with the 4500's!
Kev
Kev
How are you ? Still at NR ?
No idea about EIGRP issue, i would try upgrading to a different IOS and see if that fixes it to be honest.
Jon
Jon!!!!!!!!!!!!!!!
No mate, my contract finally came to an end end of march, currently on a short contract at Airbus though this question is for another company I've done some work for.
You doing anything yet?
Kev
Not doing anything yet, but come autumn i will be looking as it's time to get back into work i think.
I'm based in Manchester now, so will be looking in this area but if i have to go back to London then i guess i will.
So they've now got a bunch of graduates in charge of NR network ?
Jon
you looking at contracting or perm mate? can't you put yourself out on this forum mate?
what working aboard, I know it's lovely in Manchester (cough) but maybe your northern white skin would welcome some sun?
yeah they have re-named it IM-Grads
Not fussed whether contract or perm to be honest. Perhaps contract for a bit see how it goes.
It is lovely in Manchester, what are you talking about
Because it's you i had a quick search for bugs but couldn't find any mention of the issue you are talking about.
Jon
I think you should shout on here when you're looking, you got an linkin thingy as well yet?
of course it's lovely , i'm in chester at the mo.
It might be good if you could post the output of show ip eigrp topology from the 4506.
Please rate the helpfull posts.
Naidu.
I can do, before I'm talking about the switch setting the config back to stub instead of stub redisributed on reboot, so to be honest I'm not sure how it will help.
I was after a suggestion for a good IOS really which I think I now have, but will kepp the thread open to confirm if it sorted it or not once the upgrade has been done.
Cheers
Kev
