Router as a NTP server but point to external NTP clock
mcnaz-yeo
Append is my version of IOS currently running on a Cisco 7507, How is it possible or what command line should I be configure to ensure the NTP time is pointed to a external intenet NTP clock, Thanks
IOS (tm) RSP Software (RSP-JSV-M), Version 12.1(20), RELEASE SOFTWARE (fc2)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 29-May-03 20:18 by kellythw
Image text-base: 0x60010958, data-base: 0x614C4000
ROM: System Bootstrap, Version 11.1(2) [nitin 2], RELEASE SOFTWARE (fc1)
BOOTLDR: GS Software (RSP-JV-M), Version 11.1(6), RELEASE SOFTWARE (fc1)
XX1 uptime is 50 weeks, 1 day, 6 hours, 34 minutes
System returned to ROM by reload at 15:08:36 Sin Sun Jul 14 1996
System restarted at 15:50:29 Sin Fri Jan 20 2006
System image file is "slot1:rsp-jsv-mz.121-20.bin"
Richard Burts
configure:
ntp server x.x.x.x
This will tell the router to go to external server x.x.x.x to get NTP time. Make sure that the router has a route to x.x.x.x
Rick
Rick
