Router C2951 ip sla
ghtmoha153
Hello
i have Router C2951 an i need to configure ip sla , when i type ip sla i cann't find the command why?
(config)#ip sla?
sla
(config)#ip sla ?
key-chain Use MD5 Authentication for IP SLAs Control Messages
responder Enable IP SLAs Responder
server IPPM server configuration
(config)#ip sla 1 ?
% Unrecognized command
(config)#ip sla 1
% Invalid input detected at '^' marker.
(config)#sh
(config)#do sh ver
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.1(4)M4, REL EASE SOFTWARE (fc1)
Copyright (c) 1986-2012 by Cisco Systems, Inc.
Compiled Tue 20-Mar-12 19:11 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M16, RELEASE SOFTWARE (fc1)
 uptime is 1 week, 22 hours, 20 minutes
System restarted at 07:52:09 UTC Sat Jul 8 2023
System image file is "flash0:c2951-universalk9-mz.SPA.151-4.M4.bin"
Last reload type: Normal Reload
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 487424K/36864K bytes of memory.
Processor board ID FCZ16337Q5T
3 Gigabit Ethernet interfaces
1 terminal line
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
250880K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device# PID SN
*0 CISCO2951/K9 FCZ16337Q5T
Technology Package License Information for Module:'c2951'
Technology Technology-package Technology-package
Current Type Next reboot
ipbase ipbasek9 Permanent ipbasek9
security None None securityk9
uc None None None
data None None None
This old router
Try use rtr instead of ip sla
Hi @ghtmoha153
  You license level is IP BASE, that´s why you dont have IP SLA. You should have IP DATA.
This old router
Please give me an example.
