help with new home lab routing
yossryhelal
please help setup the home lab to the home modem and router
If I want to practice on static routing , do I need to subnet real ip addresses that assigned to my router? I already have the starting ip address and the end too, or I can subnet any ip addresses, I am really confussed and if I can all of the devices connected to the home ISP router which is (WISE TIGER - WT-RT8501) please help me with steps to follow from connecting the devices together into the steps to static routing between two laptops and the network lap
5 Replies 5
M02@rt37
Hello @yossryhelal,
Do you have a network topology with laptops, your home Lab (router/switch) and you ISP router?
You mean by "real IP add." the dhcp add. delivered by your ISP router from LAN port?
Thanks.
Best regards
I dont have network topology on my laptop ,
and yes this is the lab in the picture plus the ISP modem and (WISE TIGER - WT-RT8501) router connected the to the ISP modem
I mean by real ip address is do I need to use some of the allowed ip address on my router or I can create my own submask just for practice that has nothing to do with my router allowed IP addresses?
Ok @yossryhelal thanks for that explanation.
You could use your own submask just for practice goal!
Best regards
yossryhelal
great, thank you!!
Martin L
Assuming that your Tiger has working NAT and DHCP, Connect 1 Cisco switch to ISP Tiger modem then connect PC and Cisco router and other switches to that 1 switch so that your IP subnet from Tiger is shared to other PC and router.  I have seen video on how to use real gear with ISP home modem on youtube.
Alternatively, Get Packet tracer from Net Academy for practice first; study CCNA course then move to route ISP thru real router and switches.  Study CCNA course and you can find some examples of ISP for Packet tracer.
Regards, ML
**Please Rate All Helpful Responses **
