05-11-2013 01:28 AM - edited 03-04-2019 07:52 PM
My router crash by the below error, After checking the below doc it says that check show region command and see whether the address lies in the valid adsresses, how to know the address lies within the show region output given in the below output.
Link for troubleshooting BUS error:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1831/products_tech_note09186a00800cdd51.shtml
Router uptime is 2 days, 12 hours, 24 minutes
System returned to ROM by bus error at PC 0x608A79C4, address 0xB0D0B15 at 00:25:18 GMT Sun May 5 2013
System restarted at 00:26:53 GMT Sun May 5 2013
System image file is "flash:c2801-ipvoicek9-mz.124-22.YB8.bin"
Router#sh region
Region Manager:
Start End Size(b) Class Media Name
0x0E800000 0x0FFFFFFF 25165824 Iomem R/W iomem:(iomem)
0x60000000 0x6E7FFFFF 243269632 Local R/W main
0x6000F000 0x6307FFFF 50794496 IText R/O main:text
0x63083CE0 0x649D5E1F 26550592 IData R/W main:data
0x649D5E20 0x650F229F 7455872 IBss R/W main:bss
0x650F22A0 0x6E7FFFFF 158391648 Local R/W main:heap
0x80000000 0x8E7FFFFF 243269632 Local R/W main:(main_k0)
0xA0000000 0xAE7FFFFF 243269632 Local R/W main:(main_k1)
0xEE800000 0xEFFFFFFF 25165824 Iomem R/W iomem
Free Region Manager:
Solved! Go to Solution.
05-11-2013 01:31 AM
If the router crashed, then there should be a crashinfo file(s). Post the latest three.
Another thing, your IOS is pretty ancient. Be prepared. The recommandation may be as easy as upgrading a more recent IOS which supports your router's DRAM capacity.
05-11-2013 08:46 PM
Upgrade RAM to maxium and IOS to latest. Both are very easy procedures.
05-11-2013 01:31 AM
05-11-2013 02:21 AM
05-11-2013 02:32 AM
I'm not a Cisco staff, but judging from the crashinfo file of 04 May 2013, you're hitting a memory allocation issues whereby the router does not know how to return un-used memory back into the pool.
05-11-2013 02:42 AM
How to read a crashinfo??
In crashinfo where are you reading this??
What i saw is the below:
-Traceback= 0x614893A0 0x60299BFC 0x6089CB18 0x6089DEE0 0x603A7EA0 0x61E8D2E0 0x61E92928 0x6155F260 0x6155FB94 Failed to enqueue free feature data
May 4 2013 14:46:58: %SYS-2-LINKED: Bad enqueue of 6672583C in queue 64C9496C -Process= "DHCPD Receive", ipl= 4, pid= 245, -Traceback= 0x614893A0 0x60299BFC 0x6089CAA0 0x6089D6FC 0x6089DF50 0x603A7EA0 0x61E8D2E0 0x61E92928 0x6155F260 0x6155FB94 Failed to enqueue free subblock
May 4 2013 13:42:38: %ARP-3-ARPINT: ARP table accessed at interrupt level 1
, -Traceback= 0x614893A0 0x60F14468 0x60F151BC 0x60F12300 0x61AF099C 0x61AF0A5C 0x61AFE638 0x616B5810 0x6095ED7C 0x609631F4 0x6095F9BC 0x61621344 0x61621AF8 0x619D65D8 0x60835B44 0x60AC2B7C
05-11-2013 04:55 AM
There is no much point in trying to read out this stuff. As suggested above, update IOS.
05-11-2013 02:48 PM
Dears
Just need an expert confirmation before proceding.
I am running telephony version 7.1, I am planning to go with 15.0(1) M10.which is last version for 7.1 becz 8.X requires more DRAM and flash which my router is not capable.
please assist Below is the show version.
sh version
Cisco IOS Software, 2801 Software (C2801-IPVOICEK9-M), Version 12.4(22)YB8, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Fri 22-Oct-10 21:06 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
ROUTER_IPT uptime is 2 days, 12 hours, 24 minutes
Cisco 2801 (revision 7.0) with 237568K/24576K bytes of memory.
Processor board ID FCZ1131237F
2 FastEthernet interfaces
32 Serial interfaces
1 Serial(sync/async) interface
2 Channelized/Clear E1/PRI ports
2 Voice FXS interfaces
2 DSPs, 32 Voice resources
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
05-11-2013 04:42 PM
Look for the IOS based on the amount of DRAM and CF file size.
When you've made your choice, read through the Release Documents so you can determine if it will support the CUCM code that you'll be running.
05-11-2013 08:46 PM
05-11-2013 08:57 PM
Dear's
Thank you very much for replying my post,
Paolo,
The router is crashing and customer is facing downtime, customer wants an immediate/temporary solution till we upgrade the DRAM
leo,
It is CME and not the CUCM, Just need the confirmation from you experts, I am following the below link.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/33matrix.htm
http://www.cisco.com/en/US/docs/voice_ip_comm/cucme/requirements/guide/cme71spc.htm
06-15-2013 05:41 AM
Thanks buddy,
Paulo and Leo
