Router crashing
IM-Design
I have a 1811 router which is crashing at seemingly random intervals. Each time the router creates a timestamped crash file.
-Are there any tools that will allow me to see what the cause of these crashes might be?
-How can I know if the image I have in place is the problem?
What is the best way to proceed?
amit-singh
Level 8
Level 8
Charlie,
As you have a crash file with you, you can use the stack decoder tool which is used to findout the unexpected router crashes and to decode the crash.
http://www.cisco.com/cgi-bin/Support/Stackdecoder/stackdecoderinput.pl
You can try uploading another image onto the router. If its a IOS issue, then the router wont crash with the new IOS. If its some other issues you may contact TAC at Tac@cisco.com and they will take care of your problem.
HTH,Please rate if it does.
-amit singh
amit-singh
Level 8
Level 8
Charlie,
-amit singh
Thanks Amit,
I was able to use the link you suggested and found that a bug in the firmware was crashing the router periodically due to logging against an ACL.
Much Appreciated
desai.jaideep
Level 5
Level 5
Can you post the output and if possible attach the recent crashinfo file.
JD
