Router IOS upgrade issue
anmohanraj
Hi Experts,
We have 1841 router (Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(9)T1, RELEASE SOFTWARE (fc2)), currently the router up and running on "c1841-advsecurityk9-mz.124-9.T1.bin" and when we try to upgrade the IOS with "c1841-advsecurityk9-mz.124-24.T7.bin" its not taking the new IOS. After config we rebooted sevaral time, kindly advice
Below is the config and other details details
Show Version
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 30-Aug-06 15:03 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
r03163 uptime is 1 hour, 9 minutes
System returned to ROM by reload at 02:30:00 CST Mon Dec 3 2012
System restarted at 02:31:41 CST Mon Dec 3 2012
System image file is "flash:c1841-advsecurityk9-mz.124-9.T1.bin"
Boot system config
boot-start-marker
boot system flash:c1841-advsecurityk9-mz.124-24.T7.bin
boot-end-marker
sh flash
-#- --length-- -----date/time------ path
1     21855128 Nov 30 2012 17:24:50 -06:00 c1841-advsecurityk9-mz.124-9.T1.bin
2         1821 Dec 28 2006 20:35:58 -06:00 sdmconfig-18xx.cfg
3       833024 Dec 28 2006 20:36:54 -06:00 es.tar
4      1052160 Dec 28 2006 20:37:18 -06:00 common.tar
5         1038 Dec 28 2006 20:37:38 -06:00 home.shtml
6       102400 Dec 28 2006 20:37:56 -06:00 home.tar
7       491213 Dec 28 2006 20:38:16 -06:00 128MB.sdf
8      1684577 Dec 28 2006 20:38:50 -06:00 securedesktop-ios-3.1.1.27-k9.pkg
9       398305 Dec 28 2006 20:39:18 -06:00 sslclient-win-1.1.0.154.pkg
10    34393424 Oct 3 2012 08:08:52 -05:00 c1841-advsecurityk9-mz.124-24.T7.bin
18 Replies 18
Raju Sekharan
Are you getting any error on the console or it just boots with  c1841-advsecurityk9-mz.124-9.T1
Try chaning the boot statement as below
boot system flash flash:c1841-advsecurityk9-mz.124-24.T7.bin
Raju
Hello all,
I have just update the ios to c1841-advsecurityk9-mz.124-24.T7.bin then the router can't boot, I already download an other one but the problem still occurred, is everyone can help me? see the error below.
Smart Init is enabled
smart init is sizing iomem
  ID            MEMORY_REQ         TYPE
                0X003AA110 public buffer pools
                0X00211000 public particle pools
                0X00020000 Crypto module pools
                0X000021B8 Onboard USB
If any of the above Memory Requirements are
"UNKNOWN", you may be using an unsupported
configuration or there is a software problem and
system operation may be compromised.
Raji
Raji
You say see the error below but what you posted does not have any error.
As we said in the original thread the best thing to do is to connect to the console of the router, attempt to boot, and to post ALL of the console output during the attempt to boot.
As was suggested in the original thread one possible cause of problems like this is not having enough memory. Can you verify the amount of memory available in your router and the amount of memory required for this version of IOS?
Rick
Rick
I think that there is no AIM cards in the router then the router can't boot with advencedsec ios. see below the boot process.
Copyright (c) 2006 by cisco Systems, Inc.
PLD version 0x10
GIO ASIC version 0x127
c1841 platform with 262144 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
Readonly ROMMON initialized
program load complete, entry point: 0x8000f000, size: 0xcb80
program load complete, entry point: 0x8000f000, size: 0x15059d0
Self decompressing the image : ############################################################################################################ [OK]
  ID            MEMORY_REQ         TYPE
0X0588          0X00000000 UNKNOWN Card in slot 1
Allocating additional 20112742 bytes to IO Memory.
PMem allocated: 239075328 bytes; IOMem allocated: 29360128 bytes
              Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
           cisco Systems, Inc.
           170 West Tasman Drive
           San Jose, California 95134-1706
Cisco IOS Software, 1841 Software (C1841-ADVIPSERVICESK9-M), Version 12.4(10), RELEASE SOFTWARE (fc1)
Compiled Wed 16-Aug-06 01:04 by prod_rel_team
Image text-base: 0x60078FC8, data-base: 0x61C00000
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
PLD version 0x10
  ID            MEMORY_REQ         TYPE
           cisco Systems, Inc.
export@cisco.com.
PLD version 0x10
  ID            MEMORY_REQ         TYPE
Rj
Rj
Thanks for the additional information. The output is helpful, especially this line
So what card is in slot 1? Is it possible to remove that card and try booting again?
Also I notice that in your first post you tell us that you are upgrading to release c1841-advsecurityk9-mz.124-24.T7.bin but the booting output that you post is loading (C1841-ADVIPSERVICESK9-M), Version 12.4(10) which I assume is the original code. Can you verify that there is a boot system command in the configuration which points to the new image?
Rick
Rick
Card WIC in the slot 1, I have just removed the card and tried with C1841-ADVIPSERVICESK9-M and advsecurityk9 IOS  the problem still occurred.
Thanks.
Rj
Thanks for trying my suggestion about removing the card. If the problem still occurs then please boot again and post all of the console output during the attempt to boot.
Rick
Rick
Rick,
See below the console output without card in slot 1.
PLD version 0x10
  ID            MEMORY_REQ         TYPE
           cisco Systems, Inc.
export@cisco.com.
PLD version 0x10
  ID            MEMORY_REQ         TYPE
           cisco Systems, Inc.
export@cisco.com.
Hi expert,
I have a couple of 1841, see below the console output
1st
Cisco 1841 (revision 7.0) with 116736K/14336K bytes of memory.
Processor board ID FCZ..
2 FastEthernet interfaces
1 Serial(sync/async) interface
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
.... and then at this one:
Cisco 1841 (revision 6.0) with 118784K/12288K bytes of memory.
Processor board ID FC..
2 Low-speed serial(sync/async) interfaces
1 Virtual Private Network (VPN) Module
 I found that the AIM slot is empty in both router.
how to enable the vpn module?
the first one can't boot with advsecurityk9 ios (ipbase only)
Rj
Your router is doing a SILENT crash.
Try to load different IOS version.
If the crypto feature set is NOT loaded, then the VPN card cannot be enabled.
anmohanraj
We are not getting any error, i tried with your update but no luck again lodaing with an old IOS.
Can u check what is the config-register value.
Leo Laohoo
Connect to the console port and reboot the router.
Post the entire bootup process.  The file you want to run could be corrupt, hence the router is booting the second IOS.
Leo,
Here is the proof for the IOS it's healthy
#verify /md5 flash:c1841-advsecurityk9-mz.124-24.T7.bin
..................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Done!
verify /md5 (flash:c1841-advsecurityk9-mz.124-24.T7.bin) = 18d51069a95e7e6fe0aeb5929f598da3
#verify flash:c1841-advsecurityk9-mz.124-24.T7.bin
%Filesystem does not support verify operations
Verifying file integrity of flash:c1841-advsecurityk9-mz.124-24.T7.bin..........................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................................Done!
Embedded Hash   MD5 : 0BB0B36119696745D8174F8F8C55145B
Computed Hash   MD5 : 0BB0B36119696745D8174F8F8C55145B
CCO Hash        MD5 : 18D51069A95E7E6FE0AEB5929F598DA3
Signature Verified
IOS Relase Info from Cisco
Description:          ADVANCED SECURITY
Release:          12.4.24T7
Release Date:          01/Mar/2012
File Name:          c1841-advsecurityk9-mz.124-24.T7.bin
Min Memory:          DRAM 192 MB Flash 64 MB
Size:          32.80 MB (34393424 bytes)
MD5 Checksum:          18d51069a95e7e6fe0aeb5929f598da3
