Router IOS upgrade issue
anmohanraj
Hi Experts,
We have 1841 router (Cisco IOS Software, 1841 Software (C1841-ADVSECURITYK9-M), Version 12.4(9)T1, RELEASE SOFTWARE (fc2)), currently the router up and running on "c1841-advsecurityk9-mz.124-9.T1.bin" and when we try to upgrade the IOS with "c1841-advsecurityk9-mz.124-24.T7.bin" its not taking the new IOS. After config we rebooted sevaral time, kindly advice
Below is the config and other details details
Show Version
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Wed 30-Aug-06 15:03 by prod_rel_team
ROM: System Bootstrap, Version 12.4(13r)T, RELEASE SOFTWARE (fc1)
r03163 uptime is 1 hour, 9 minutes
System returned to ROM by reload at 02:30:00 CST Mon Dec 3 2012
System restarted at 02:31:41 CST Mon Dec 3 2012
System image file is "flash:c1841-advsecurityk9-mz.124-9.T1.bin"
Boot system config
boot-start-marker
boot system flash:c1841-advsecurityk9-mz.124-24.T7.bin
boot-end-marker
sh flash
-#- --length-- -----date/time------ path
1     21855128 Nov 30 2012 17:24:50 -06:00 c1841-advsecurityk9-mz.124-9.T1.bin
2         1821 Dec 28 2006 20:35:58 -06:00 sdmconfig-18xx.cfg
3       833024 Dec 28 2006 20:36:54 -06:00 es.tar
4      1052160 Dec 28 2006 20:37:18 -06:00 common.tar
5         1038 Dec 28 2006 20:37:38 -06:00 home.shtml
6       102400 Dec 28 2006 20:37:56 -06:00 home.tar
7       491213 Dec 28 2006 20:38:16 -06:00 128MB.sdf
8      1684577 Dec 28 2006 20:38:50 -06:00 securedesktop-ios-3.1.1.27-k9.pkg
9       398305 Dec 28 2006 20:39:18 -06:00 sslclient-win-1.1.0.154.pkg
10    34393424 Oct 3 2012 08:08:52 -05:00 c1841-advsecurityk9-mz.124-24.T7.bin
18 Replies 18
What's your DRAM size?  You have192 mb of DRAM?
Same thing, reboot the router.  I want to see the bootup process.
I cannot reboot the router now, find the requested info below
Cisco 1841 (revision 6.0) with 234496K/27648K bytes of memory.
2 FastEthernet interfaces
1 Serial interface
1 Virtual Private Network (VPN) Module
WIC T1-DSU
DRAM configuration is 64 bits wide with parity disabled.
191K bytes of NVRAM.
62720K bytes of ATA CompactFlash (Read/Write)
Its look like problem in flash bin files order.
The original poster has said that there is a boot system command pointing at c1841-advsecurityk9-mz.124-24.T7.bin and not at the older image. If that is the case then the order of files in flash does not matter.
I agree with the suggestion that to understand this issue we need to see the output to the console during the boot process. With the correct setting of the config register and the correct boot system commands the router shoujld be booting the new image. If it is not then there should be some message to the console during boot that would explain why.
Rick
Rick
