Router on a stick - AP and switch can't ping subifs
NicP270591
Experts,
I am deploying a wireless network with multiple SSID's - 1242 trunked to 3560. 3560 trunked to 2811 subifs. Native VLAN 99 set at every point. Wireless clients can connect to SSID fine, but do not get DHCP from the router. The switch can ping BVI interface on AP (VLAN 99), and its own VLAN 99 of course, but cannot reach router loopback, 99, or subifs. Phones and desktop PC's in their respective VLAN's work fine and connect with DHCP etc. I am stumped. Seeing as the switch can ping the AP, but clients on the AP cannot ping the switch or router, or get DHCP, I am assuming there is a problem with the switch rather than the AP.
SWITCH
vlan 21
name VLAN-21-WLAN
vlan 22
name VLAN-22-GUEST-WLAN
vlan 99
name VLAN-99-NETMGT
interface Loopback0
description loopback
ip address 192.102.10.2 255.255.255.255
no ip route-cache
interface FastEthernet0/47
description to AP 1
switchport trunk native vlan 99
switchport trunk allowed vlan 21,22,40,41,51,99
switchport mode trunk
interface FastEthernet0/48
description to 2811 fa0/0
switchport trunk allowed vlan 12,20-22,30,40,41,50,51,60,99
interface Vlan99
ip address 192.102.99.2 255.255.255.192
no ip route-cache
ROUTER
ip dhcp pool VLAN-21-WLAN
   network 192.102.21.0 255.255.255.192
   default-router 192.102.21.1
   dns-server 61.88.88.88 192.102.21.1 8.8.8.8
   lease 7
ip dhcp pool VLAN-22-GUEST-WLAN
   network 192.102.22.0 255.255.255.0
   default-router 192.102.22.1
interface Loopback0
description L,OP,Rothwell,4022
ip address 192.102.10.1 255.255.255.192
interface FastEthernet0/0
description to SW 0/48
no ip address
no ip redirects
ip flow ingress
ip nat inside
ip virtual-reassembly in
duplex auto
speed 100
interface FastEthernet0/0.21
description VLAN-21-WLAN
encapsulation dot1Q 21
ip address 192.102.21.1 255.255.255.192
no ip redirects
no ip proxy-arp
ip flow ingress
ip nat inside
interface FastEthernet0/0.22
description VLAN-22-GUEST-WLAN
encapsulation dot1Q 22
ip address 192.102.22.1 255.255.255.0
no ip redirects
no ip proxy-arp
ip flow ingress
interface FastEthernet0/0.99
description VLAN-99-NETMGT,OP,Rothwell,4022
encapsulation dot1Q 99 native
no ip redirects
no ip proxy-arp
ip flow ingress
AP
dot11 ssid Guest Connect
   vlan 22
   authentication open
   authentication key-management wpa
   guest-mode
   mbssid guest-mode
   wpa-psk ascii 7 XXXXX
dot11 ssid Corporate Connect
   vlan 21
   authentication open
nterface Dot11Radio0
no ip address
no ip route-cache
encryption vlan 21 key 1 size 128bit 7 XXXX transmit-key
encryption vlan 21 mode wep mandatory
encryption mode ciphers tkip
encryption vlan 22 mode ciphers tkip
ssid Guest Connect
mbssid
station-role root
bridge-group 1
bridge-group 1 block-unknown-source
no bridge-group 1 source-learning
no bridge-group 1 unicast-flooding
bridge-group 1 spanning-disabled
interface Dot11Radio0.21
no ip route-cache
bridge-group 21
bridge-group 21 subscriber-loop-control
bridge-group 21 block-unknown-source
no bridge-group 21 source-learning
no bridge-group 21 unicast-flooding
bridge-group 21 spanning-disabled
interface Dot11Radio0.22
no ip route-cache
bridge-group 2
bridge-group 2 subscriber-loop-control
bridge-group 2 block-unknown-source
no bridge-group 2 source-learning
no bridge-group 2 unicast-flooding
bridge-group 2 spanning-disabled
interface FastEthernet0.21
no ip route-cache
interface FastEthernet0.22
no ip route-cache
interface FastEthernet0.99
no ip route-cache
bridge-group 1
interface BVI1
ip address 192.102.99.3 255.255.255.192
no ip route-cache
ip http server
no ip http secure-server
ip http help-path http://www.cisco.com/warp/public/779/smbiz/prodconfig/help/eag
bridge 1 route ip
You need to assign your bridge-groups under the subinterfaces for f0 as well. Your native has it, but the other two do not...
bridge-group 21
no ip route-cache
bridge-group 2
no ip route-cache
HTH,
John
*** Please rate all useful posts ***
HTH, John *** Please rate all useful posts ***
7 Replies 7
Praveen AR
HI Nic,
Could you please confirm reachability for router sub interface from AP's.
Praveen
Hello Praveen!
If I ping 192.102.21.1 or 22.1 from the AP's I get 0% success rate.
Nic.
I doubt  problem in AP configuration.could you please recheck  your AP config.
Praveen
Praveen,
A bit unclear there. I am assuming youre saying you're doubting a problem in the router and switch but to check AP configuration?
Nic.
bridge-group 21
no ip route-cache
bridge-group 2
no ip route-cache
HTH,
John
John,
Solved it in one! Can't believe I missed that. Thank you!, and Praveen, helpful as always!
Nic.
Hi Nic,
I doubt configuration in AP only ,Even you can confirm swapping the switch connected port  and AP .
I think there is no issues with switch config ,doubt  problem in trunking between switch and AP.
