08-08-2006 12:22 AM - edited 03-03-2019 01:35 PM
Hi guys,
i have here a mc3810 router with fxs port. I tried upgrading the ios to enable voip support, but after upgrading and reloading the router, it kept on rebooting. what seems to be the problem ?
MC3810 platform with 32768 Kbytes of main memory
program load complete, entry point: 0x23000, size: 0x11437c
Self decompressing the image : ################################################################################################################ [OK]
Cannot detect card in slot 3, change clocking to UIO:
Initialize Flash file system.....
total size = 8388608
flashfs[4]: 1 files, 1 directories
flashfs[4]: 1 orphaned files, 1 orphaned directories
flashfs[4]: Total bytes: 8128000
flashfs[4]: Bytes used: 8040960
flashfs[4]: Bytes available: 87040flashfs[4]: flashfs fsck took 21 seconds.
flashfs[4]: Initialization complete.
%PARSER-4-BADCFG: Unexpected end of configuration file.
%SYS-4-CONFIG_NEWER: Configuration from version 12.0 may not be correctly understoodRead file (flash:mc3810-a2isv5-mz.122-23f.bin) into ram (0x417330) ...
flashfs[4]: dostat, unable to lookup filemap for fileid 0!
Finished - 8102680 bytes
%SYS-6-BOOT_MESSAGES: Messages above this line are from the boot loader.
UART re-init OK (disable AUX port)
program load complete, entry point: 0x23000, size: 0x7ba1fc
tnx
jeff
08-08-2006 12:42 AM
According to the Cisco.com, it require 64M DRAM, did you confirm there is sufficient memory in the router ?
Hope this helps.
08-08-2006 12:55 AM
Is there any way i can revert the old ios ? Or is there any ios for mc3810 that supports voip that requires 32MB only ?
tnx.
jeff
08-08-2006 02:20 AM
Hi Jeff,
Use break sequence CNTRL + Break) to break the boot sequence of the router and it will boot to Rommon.
Once in rommon you can either use xmodem or TFTPdnld for uploading the original ios
Use the following links for more detials
http://www.cisco.com/warp/public/130/xmodem_generic.html
Narayan
08-08-2006 03:59 PM
After following the instructions, the command tftpdnld did not respond.
rommon 9 > tftpdnld
monitor: command "tftpdnld" not found
rommon 10 > tftpdnld -r
jeff
08-08-2006 05:34 PM
If TFTP not work, try to use XMODEM to download the IOS.
08-09-2006 02:27 AM
Jeff,
If you use Xmodem please note this is really slow, you can best find the smallest ios available for this device and then do a normal upgrade after this.
- Please rate this post if it helps.
08-10-2006 03:36 AM
xmodem would be the best option for the IOS upgrade, in this situation, Eventhough it may time time to get it done. It uses the console cable to transfer data, Please check the bits per second thats Ideal for the device before transfering the IOS, and the doc could be available from the Cisco Site.
08-10-2006 05:24 PM
Hi guys,
I tried formatting the flash and then booting it. Then i did the normal ios transfer and it works well now. Thanks for all the help.
jeff
