Router receiving config from APIC-EM is losing config on power cycle
SurCullsALot
Hello all,
We are acting as a pre-deployment staging centre for our client.
We push a config down to C-1111 routers using the APIC-EM module accessed via a jump server on the customers’ network.
C-1111 takes a config successfully, however does not hold the config when it is powered down.
The config file being pushed does not include a "Write" command.
Is the PNP agent / service used to connect the router to the APIC module responsible for applying a "Write" command or does the command need to be included in the config file being applied?
Thanks in advance
Torbjørn
What is the value of the configuration register? It sounds like the router might be booting with 0x2142 set.
Happy to help! Please mark as helpful/solution if applicable.
Get in touch: https://torbjorn.dev
Hi Torbjorn,
Router is fresh out of the box so presume default of 0x2102. I will check in the morning jst to make sure and report back.
Still interested as to how APIC applys a given config and if it requires the write command to be in the config file?
SurCullsALot
So its definately not the configuration register, I double checked this morning. As far as I can see running config is not being saved as startup config.
Is this something APIC-EM should do or does the applied config require a write command after end?
