Router Replacment Problem
saadeng2001
I want to replace a faulty router with new one,i did all configuration as the old one,attached the new and it is not working,this is the configuration of both. I do apprecite any help.
paolo bevilacqua
What exactly is not working ?
Goutam Sanyal
Level 4
Level 4
post the details - what is not working exactly? Or you can check the Ports (Serial/fast-Giga Ethernet) are not administratively down.
Goutam
Please rate if it works
Also check the serial interfaces. The interface numbers might not be matching with the physical connections.
Rate if this works....
Danilo Dy
Thus the faulty router and replacement router the same model and running the same IOS version/feature set?
Take note that if the model is different, module slot/interface number may differ. Also, if the model is different, module from the old router may not be compatible to the replacement router (i.e. firmware/release verion).
If the IOS version/feature set is different, some configuration lines from the faulty router may not be available in the replacement router.
Dandy
