Router Selection for 600Mbps MetroE circuit
PATRICK HARRIS
Level 4
Level 4
Need advice on selecting the appropriate router to support a 600Mbps WAN circuit we utilize for replication. Currently, we are running a 2821 router on a 300Mbps circuit. I have looked at the 2900/3900 series routers, however I want to select the right hardware that will provide for future growth to 1Gbps if necessary.
paolo bevilacqua
Check attached.
Joseph W. Doherty
Disclaimer
The Author of this posting offers the information contained within this posting without consideration and with the reader's understanding that there's no implied or expressed suitability or fitness for any purpose. Information provided is for informational purposes only and should not be construed as rendering professional advice of any kind. Usage of this posting's information is solely at reader's own risk.
Liability Disclaimer
In no event shall Author be liable for any damages whatsoever (including, without limitation, damages for loss of use, data or profit) arising out of the use or inability to use the posting's information even if Author has been advised of the possibility of such damage.
Posting
In Cisco's current router line-up, for 600 Mbps you'll likely want to consider using an entry ASR 1000 series routers.  (Note: the 7200s also are well positioned for this capacity, but http://www.cisco.com/en/US/prod/collateral/routers/ps341/end_of_life_c51-681414.html.)
An alternative for 600 Mbps MetroE, might be a MetroE switch (or even an ordinary LAN L3) switch; really depends on your feature requirements.
