PIX 515 NAT issue
williamtwomey
Running 7.x
I'm trying to set up NAT overloading (so all inside hosts can access the internet through one public IP) and also PAT entries for other public IP addresses.
PAT is working fine, but NAT is not. Was hoping someone could point me in the right direction.
[code]
PIX Version 7.1(2)
hostname pixfirewall
domain-name default.domain.invalid
enable password <snip> encrypted
names
interface Ethernet0
nameif outside
security-level 0
ip address 1.1.1.58 255.255.255.248
interface Ethernet1
nameif inside
security-level 100
ip address 10.0.0.254 255.255.255.0
access-list acl_outbound extended permit tcp any any
access-list acl_outbound extended permit ip any any
access-list acl_outbound extended permit udp any any
access-list acl_outbound extended permit icmp any any
access-list 101 extended permit icmp any any
access-list 101 extended permit ip any any
access-list 101 extended permit tcp any any
access-list 101 extended permit udp any any
access-list INPUT_ACL extended permit ip any any
access-list INPUT_ACL extended permit icmp any any
access-list INPUT_ACL extended permit tcp any any
access-list acl_grp extended permit icmp any any
access-list OUTPUT_ACL extended permit ip any any
icmp permit any outside
icmp permit any inside
arp timeout 14400
global (outside) 1 interface
global (outside) 2 1.1.1.61
nat (inside) 2 10.0.0.102 255.255.255.255
nat (inside) 1 0.0.0.0 0.0.0.0
static (inside,outside) tcp 1.1.1.58 www 10.0.0.100 www netmask 255.255.255
static (inside,outside) tcp 1.1.1.58 https 10.0.0.100 https netmask 255.255
static (inside,outside) tcp 1.1.1.58 6667 10.0.0.102 6667 netmask 255.255.2
static (inside,outside) tcp 1.1.1.58 ldap 10.0.0.102 ldap netmask 255.255.2
static (inside,outside) tcp 1.1.1.58 ssh 10.0.0.102 ssh netmask 255.255.255
static (inside,outside) tcp 1.1.1.58 509 10.0.0.100 509 netmask 255.255.255
static (inside,outside) tcp 1.1.1.58 902 10.0.0.100 902 netmask 255.255.255
static (inside,outside) 1.1.1.59 10.0.0.101 netmask 255.255.255.255
access-group INPUT_ACL in interface outside
access-group OUTPUT_ACL in interface inside
rip inside default version 1
route outside 0.0.0.0 0.0.0.0 67.53.153.57 1
timeout xlate 3:00:00
timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02
timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00
timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00
timeout uauth 0:05:00 absolute
[/code]
NAT from inside:10.0.0.102 to outside:10.0.0.102 flags iI
This means that it did identity NAT which is simply no NAT and so that's why your ping ain't working if you did it from
10.0.0.102.
Now why did it do this because normaly you have to specify that the traffic shouldn't be natted.
Is a ping from 10.0.0.101 is working ?
if it ain't can you do a clear xlate and try again.
Could you
also post  output from following to get sure of the  NAT statements:
show run global
show run nat
Regards.
Alain
5 Replies 5
cadet alain
can you get rid of these 2 lines :
then initiate a connection from inside and post output of sh xlate detail and sh conn detail
Regards.
Alain
Thanks, I tried pinging 8.8.8.8 from inside for this test
# sh conn detail
93 in use, 378 most used
Flags: A - awaiting inside ACK to SYN, a - awaiting outside ACK to SYN,
       B - initial SYN from outside, C - CTIQBE media, D - DNS, d - dump,
       E - outside back connection, F - outside FIN, f - inside FIN,
       G - group, g - MGCP, H - H.323, h - H.225.0, I - inbound data,
       i - incomplete, J - GTP, j - GTP data, K - GTP t3-response
       k - Skinny media, M - SMTP data, m - SIP media, O - outbound data,
       P - inside back connection, q - SQL*Net data, R - outside acknowledged F,
       R - UDP SUNRPC, r - inside acknowledged FIN, S - awaiting inside SYN,
       s - awaiting outside SYN, T - SIP, t - SIP transient, U - up
ICMP outside:8.8.8.8/0 inside:10.0.0.102/29889
# sh xlate detail
9 in use, 16 most used
Flags: D - DNS, d - dump, I - identity, i - dynamic, n - no random,
       r - portmap, s - static
NAT from inside:10.0.0.101 to outside:1.1.1.59 flags s
TCP PAT from inside:10.0.0.102/6667 to outside:1.1.1.58/6667 flags sr
TCP PAT from inside:10.0.0.102/389 to outside:1.1.1.58/389 flags sr
TCP PAT from inside:10.0.0.102/22 to outside:1.1.1.58/22 flags sr
Guessing the problem is with "NAT from inside:10.0.0.102 to outside:10.0.0.102 flags iI", not sure how to resolve this however to have it use outside:public-ip
Would anyone happen to have a PIX 515 example config using NAT and PAT together?
10.0.0.102.
Could you
show run global
show run nat
Regards.
Alain
clear xlate solved this, thanks a lot!
Both NAT and PAT are working now, with only the one global line.
