Router SFP media type unknown
ohforce55
ISR 4331 Router recognizes when plugging in the RJ45 SFP but when I do sh int g0/0/2 (where I plugged the sfp in), it says media=type unknown...
Router#sh int g0/0/2
GigabitEthernet0/0/2 is down, line protocol is down
Hardware is ISR4331-3x1GE, address is 00a3.d186.be22 (bia 00a3.d186.be22)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is unknown media type
output flow-control is on, input flow-control is on
But when I do sh inv, sh do the following command, it shows the SFP....
Router#sh hw-module subslot 0/0 transceiver 2 IDprom
IDPROM for transceiver Gigabitethernet0/0/2:
Description = SFP or SFP+ optics (type 3)
Transceiver Type: = GE T (26)
Product Identifier (PID) = SFP-GE-T
Vendor Revision =
Serial Number (SN) = MTC2103055U
Vendor Name = CISCO-METHODE
Vendor OUI (IEEE company ID) = 00.00.00 (0)
CLEI code = IPUIAPARAB
Cisco part number = 30-1421-02
Device State = Enabled.
Date code (yy/mm/dd) = 17/01/27
Connector type = Unknown.
Encoding = 8B10B
NRZ
Nominal bitrate = GE (1300 Mbits/s)
Minimum bit rate as % of nominal bit rate = not specified
Maximum bit rate as % of nominal bit rate = not specified
Router#
Router#sh inv
NAME: "Chassis", DESCR: "Cisco ISR4331 Chassis"
PID: ISR4331/K9 , VID: V04, SN: FLM2121V05J
NAME: "Power Supply Module 0", DESCR: "250W AC Power Supply for Cisco ISR 4330"
PID: PWR-4330-AC , VID: V02, SN: DCA211410B8
NAME: "Fan Tray", DESCR: "Cisco ISR4330 Fan Assembly"
PID: ACS-4330-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller"
PID: ISR4331/K9 , VID: , SN:
NAME: "NIM subslot 0/0", DESCR: "Front Panel 3 ports Gigabitethernet Module"
PID: ISR4331-3x1GE , VID: V01, SN: JAB092709EL
NAME: "subslot 0/0 transceiver 2", DESCR: "GE T"
PID: SFP-GE-T , VID: , SN: MTC2103056T
NAME: "module 1", DESCR: "Cisco ISR4331 Built-In SM controller"
NAME: "module R0", DESCR: "Cisco ISR4331 Route Processor"
PID: ISR4331/K9 , VID: V04, SN: FDO21132EZG
NAME: "module F0", DESCR: "Cisco ISR4331 Forwarding Processor"
Is it normal?
sorry that's your correct sfp below and it should work on 3.13 IOS version also as per doc
SFP-GE-T Yes Yes Yes Yes Yes 16.4.1 3.13 10/100/1000BASE-T SFP (NEBS 3 ESD)
Cisco 4331 ISR
The Cisco 4331 ISR provides these capabilities:
  • One single-wide SM slot
  • Two single-wide NIM slots that can combined into one double-wide (NIM1 and NIM2).
  • One 10/100/1000 RJ-45 Ethernet port for system management (labeled {MGMT} on the right of the connector)
  • One USB Type A host port
  • One USB mini-Type B console (placed next to the RJ-45 console port)
  • One RJ-45 console port
  • One RJ-45 auxiliary port
  • Three GE ports allocated among two RJ45 and two SFP as:
One combo port with 10/100/1000 RJ-45 Ethernet port or SFP Ethernet port (labeled GE0/0/0)
One dedicated 10/100/1000 RJ-45 Ethernet port (labeled GE0/0/1)
One dedicated SFP Ethernet port (labeled GE0/0/2)
17 Replies 17
Mark Malone
Its supported sfp but you need a minimum version for that sfp , are you running the below or higher ?
https://www.cisco.com/c/en/us/products/routers/4000-series-integrated-services-routers-isr/relevant-interfaces-and-modules.html
GLC-TE Yes Yes Yes Yes Yes 16.4.1 3.16 10/100/1000BASE-T
Thank you so much for your reply.
You mean IOS?
My company's recommendation is to have 3.13.7S.
Will that work with the IOS 3.13.7S?
Router#sh ver
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
Cisco IOS Software, ISR Software (X86_64_LINUX_IOSD-UNIVERSALK9-M), Version 15.5(3)S4b, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2016 by Cisco Systems, Inc.
Compiled Mon 17-Oct-16 20:23 by mcpre
Cisco IOS-XE software, Copyright (c) 2005-2016 by cisco Systems, Inc.
All rights reserved. Certain components of Cisco IOS-XE software are
licensed under the GNU General Public License ("GPL") Version 2.0. The
software code licensed under GPL Version 2.0 is free software that comes
with ABSOLUTELY NO WARRANTY. You can redistribute and/or modify such
GPL code under the terms of GPL Version 2.0. For more details, see the
documentation or "License Notice" file accompanying the IOS-XE software,
or the applicable URL provided on the flyer accompanying the IOS-XE
software.
ROM: IOS-XE ROMMON
Router uptime is 14 minutes
Uptime for this control processor is 15 minutes
System returned to ROM by reload at 13:47:30 EDT Tue Aug 8 2017
System image file is "bootflash:isr4300-universalk9.03.16.04b.S.155-3.S4b-ext.SPA.bin"
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Suite License Information for Module:'esg'
Suite Suite Current Type Suite Next reboot
FoundationSuiteK9 None None None
securityk9
appxk9
AdvUCSuiteK9 None None None
uck9
cme-srst
cube
Technology Package License Information:
Technology Technology-package Technology-package
Current Type Next reboot
appxk9 None None None
uck9 None None None
securityk9 securityk9 Permanent securityk9
ipbase ipbasek9 Permanent ipbasek9
cisco ISR4331/K9 (1RU) processor with 1648789K/6147K bytes of memory.
Processor board ID FLM2121V05J
3 Gigabit Ethernet interfaces
32768K bytes of non-volatile configuration memory.
4194304K bytes of physical memory.
3125247K bytes of flash memory at bootflash:.
Router#
Cisco 4331 ISR
I would try the 3.13.7S as its on 3.16 see if it makes a difference and see  if it gets recognised
Thank you again!
The thing I'm wondering is that the doc shows minimum IOS. The IOS that is in the router has higher version....
Why isn't it worked? Is it related only with SFP?
could be a number of reasons most likely software related , that 3.16 is a fairly good version though my GLC-Ts worked fine in it but we had issues on some earlier images where only v2 sfps would work and not v1 that was stamped on the actual sfp sticker on the back of it
Also make sure its cisco branded sfp and not a 3rd party type as some of them don't work at all either
there's been a few discussions on the 4331s and different types of sfps not working usually comes down to some firmware or software version miss-match between the sfps and router
https://supportforums.cisco.com/discussion/13025801/4331-transceiver-not-supportednot-compatible
https://supportforums.cisco.com/discussion/13305171/isr-4331-interface
I have one more question :)
Media type is now shown as T
Hardware is ISR4331-3x1GE, address is 00a3.d186.bfd2 (bia 00a3.d186.bfd2)
Full Duplex, 1000Mbps, link type is auto, media type is T
But here it says unkown.. Is it normal?
Router#sh hw-module subslot 0/0 transceiver 2 idprom
Product Identifier (PID) = SP7041-E-R
Vendor Revision =
Serial Number (SN) = MTC2103056T
Encoding = 8B10B
NRZ
Router#
The unknown is standard and you want to see T as its a base T SFP so your good :)
Thank you!
Hi Mark,
After rebooting the router, the media type is not shown...
It said 'T' before but now it is gone...
GigabitEthernet0/0/2 is administratively down, line protocol is down
output flow-control is unsupported, input flow-control is unsupported
Hi is it still the same if you bring the interface up , its admin down ? it was working so strange reboot would cause an issue , still on same software yes , it didn't roll back ?
ah.... hehe
after no shut, it works... :)
thanks!
After downgrading to 3.13.7S, it works!!!
Thank you!!
I have Cisco ISR4331 Route Processor and below are the sho ver.
Router#sh version
But when i insert the SFP module it is  not showing in Inve? Router#sh inventory also port is showing down..
Pls suggest
thanks
Vikas Giri
