08-08-2017 10:28 AM - edited 03-05-2019 08:58 AM
ISR 4331 Router recognizes when plugging in the RJ45 SFP but when I do sh int g0/0/2 (where I plugged the sfp in), it says media=type unknown...
Router#sh int g0/0/2
GigabitEthernet0/0/2 is down, line protocol is down
Hardware is ISR4331-3x1GE, address is 00a3.d186.be22 (bia 00a3.d186.be22)
MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
Keepalive not supported
Full Duplex, 1000Mbps, link type is auto, media type is unknown media type
output flow-control is on, input flow-control is on
But when I do sh inv, sh do the following command, it shows the SFP....
Router#sh hw-module subslot 0/0 transceiver 2 IDprom
IDPROM for transceiver Gigabitethernet0/0/2:
Description = SFP or SFP+ optics (type 3)
Transceiver Type: = GE T (26)
Product Identifier (PID) = SFP-GE-T
Vendor Revision =
Serial Number (SN) = MTC2103055U
Vendor Name = CISCO-METHODE
Vendor OUI (IEEE company ID) = 00.00.00 (0)
CLEI code = IPUIAPARAB
Cisco part number = 30-1421-02
Device State = Enabled.
Date code (yy/mm/dd) = 17/01/27
Connector type = Unknown.
Encoding = 8B10B
NRZ
Nominal bitrate = GE (1300 Mbits/s)
Minimum bit rate as % of nominal bit rate = not specified
Maximum bit rate as % of nominal bit rate = not specified
Router#
Router#sh inv
NAME: "Chassis", DESCR: "Cisco ISR4331 Chassis"
PID: ISR4331/K9 , VID: V04, SN: FLM2121V05J
NAME: "Power Supply Module 0", DESCR: "250W AC Power Supply for Cisco ISR 4330"
PID: PWR-4330-AC , VID: V02, SN: DCA211410B8
NAME: "Fan Tray", DESCR: "Cisco ISR4330 Fan Assembly"
PID: ACS-4330-FANASSY , VID: , SN:
NAME: "module 0", DESCR: "Cisco ISR4331 Built-In NIM controller"
PID: ISR4331/K9 , VID: , SN:
NAME: "NIM subslot 0/0", DESCR: "Front Panel 3 ports Gigabitethernet Module"
PID: ISR4331-3x1GE , VID: V01, SN: JAB092709EL
NAME: "subslot 0/0 transceiver 2", DESCR: "GE T"
PID: SFP-GE-T , VID: , SN: MTC2103056T
NAME: "module 1", DESCR: "Cisco ISR4331 Built-In SM controller"
NAME: "module R0", DESCR: "Cisco ISR4331 Route Processor"
PID: ISR4331/K9 , VID: V04, SN: FDO21132EZG
NAME: "module F0", DESCR: "Cisco ISR4331 Forwarding Processor"
Is it normal?
Solved! Go to Solution.
04-14-2018 08:51 AM
I have Cisco ISR4331 Route Processor and below are the sho ver.
Router#sh version
Cisco IOS XE Software, Version 03.16.04b.S - Extended Support Release
But when i insert the SFP module it is not showing in Inve? Router#sh inventory also port is showing down..
Pls suggest
thanks
Vikas Giri
12-12-2018 04:04 AM
08-19-2023 06:59 AM
I have same problem with n9k
1G rg45 SFP listed unknown in nexsus 9000
anyone have a solution for this issue
