12-07-2011 05:56 AM - edited 03-04-2019 02:33 PM
We will be adding three locations to a MPLS connection. These are remote locations without a lot of traffic and wanted to know if something like the Cisco 1941/K9 would be sufficient? The three sites will be getting 20Mbps connectivity.
Thanks in advance.
Solved! Go to Solution.
12-07-2011 06:16 AM
For about 20M 1941 is more than enough
Refer to the bellow link
http://www.cisco.com/web/partners/downloads/765/tools/quickreference/routerperformance.pdf
Hope this help
If helpful rate
12-07-2011 06:16 AM
Hope this help
If helpful rate
12-07-2011 06:22 AM
Yes it does. Thanks.
I also have a 1921 ISR would that be the same as the 1941? The 1921 ISR will be getting a 100Mbps connection to a 2911 ISR. The reason I am asking is because I didn't see the 1921 on the PDF.
12-07-2011 07:01 AM
You can check it's data sheet bout for 20m I would say it won't be a problem Unless you need high level of encryption on top of that in this case you need to be careful
Hope this help
If helpful rate
12-07-2011 06:22 AM
Hi Richard,
Yes, I have 1941 at one of my site in Germany and it handling 30 MB link and another 4 MB internet link.
Please rate the helpfull posts.
Naidu.
