Wan DSL / ISDN Failover config
lgogniat1
I try to configure a cisco router to set up a failover between ADSL and ISDN lines.
The ISDN line only works if I call at the right dialer.
ADSL line also works if I call the associated dialer
The problem is that automatically switches between ISDN and ADSL is not working.
Can someone help me to understand the problem in my config file ?
Thank you,
Current configuration : 2635 bytes
version 12.4
service tcp-keepalives-in
service tcp-keepalives-out
service password-encryption
hostname cisco
boot-start-marker
boot-end-marker
security authentication failure rate 3 log
logging console critical
enable secret 5 XXXXXXXXXXXXXXXX
no aaa new-model
resource policy
ip cef
ip tcp synwait-time 10
ip name-server 194.2.0.20
ip name-server 194.2.0.50
isdn switch-type basic-net3
username administrateur privilege 15 secret 5 XXXXXXXXXXXXXXXXXXXX
interface FastEthernet0
ip address XXX.XXX.XXX.XXX 255.255.255.248
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
ip nat enable
ip route-cache flow
duplex auto
speed auto
interface BRI0
no ip address
no ip redirects
no ip unreachables
no ip proxy-arp
encapsulation hdlc
ip route-cache flow
dialer pool-member 2
dialer idle-timeout 10
isdn point-to-point-setup
no keepalive
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface ATM0
no ip address
no atm ilmi-keepalive
pvc 8/35
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
dsl operating-mode auto
interface Vlan1
no ip address
interface Dialer0
ip unnumbered FastEthernet0
ip mtu 1470
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap callin
ppp chap hostname XXX@XXX
ppp chap password 7 XXXXXXXXXX
interface Dialer1
ip address negotiated
ip nat outside
ip nat enable
encapsulation ppp
dialer pool 2
dialer idle-timeout 170
dialer string 0860XXXXXX
dialer-group 2
no keepalive
no cdp enable
ppp chap password 7 XXXXXXXXXXXX
ip route 0.0.0.0 0.0.0.0 1.1.1.1
ip route 0.0.0.0 0.0.0.0 Dialer1 50
no ip http server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer1 overload
access-list 1 permit XXXXXXXX 0.0.0.7
dialer-list 1 protocol ip permit
dialer-list 2 protocol ip permit
control-plane
banner login ^CAuthorized access only!
DIsconnect IMMEDIATELY if you are not an authorized user!^C
line con 0
login local
transport output telnet
line aux 0
login local
line vty 0 4
privilege level 15
login local
transport input telnet
line vty 5 15
privilege level 15
login local
end
configure the following on your dialer associated with DSL
backup interface dialer (number of your dialer for ISDN)
HTH,
Smitesh
Why don't you try to use IP SLA:
conf t
ip sla 1
icmp-echo 4.2.2.2
exit
ip sla schedule 1 life forever start-time now
track 123 rtr 1 reachability
ip route 4.2.2.2 255.255.255.255 Dialer0 (you have 1.1.1.1)
ip route 0.0.0.0 0.0.0.0 Dialer0 track 123
You would need to adjust/tweak NAT if these are going out to Internet.
Regards.
