Router to Router is slow
nareth_norung
Dear All,
Coul you find the problem, i had two router 1721,wic-1T and V.35.Then i connected router 1721 to 1721 by V.35(not lease line or vpn, it simple connect),and I use protocol eigrp 50 for routing.After I configure already in router , i can ping PC to PC cross by router but when i transfer data 2 MB it very slow and take time.
Best Regard,
alsayed
Try to do an Extended ping;than when u reach the DataGram Frame increse it first to 1Mbps,and see the result!
10xs
Hello
Could you tell me how slow it is and how much time it takes?
What is the clockrate on the serial link?
Dou you see CRC's on the "show interface x"?
An other question. Why use a dynamic routing prot on a B2B situation?
Ciao
Dear Sir,
Sorry for reply late.
1.when i send 2 MB it take 2minute.
2.I set Clock Rate 64000.
3.Why use a dynamic routing prot on a B2B situation?
+The answer: Now the real system using dynamic routing. I had test route stastic also.
Best Regard,
