Routers with dual power supply option.
What is the lowest end router that can have dual power supplies?
Will any of the 2900 series take a 2nd power supply?
rfalconer.sffcu
Level 3
Level 3
For ISR, the 2900 doesn't have a 2nd supply. Only RPS is supported for redundant power.
3900 does support 2nd supply.
aaunario
Routers with “Redundant power supplies” starts with the Cisco 4431 ISR.
(Well of course, this is 5 years after the question was asked.)
Sam Smiley
Level 3
Level 3
As noted you can add a RPS 2300 to the 2900 series, however to answer your questions the 3900 ISR G2 does have redundant power supplies support.
Sam
