Routing and SD-WAN
Labels
Welcome to the Cisco Community Ask Me Anything EventWe invite you to participate in our upcoming Ask Me Anything (AMA) conversation. Please submit your questions from Monday, June 1, 2026, through Tuesday, June 30, 2026. Our experts Ashwin Murali (En...
I have a C8000v SDWAN edge running IOS-XE 17.15.3a, it acts as a transit hub for the SDWAN sites to connect to a PaloAlto firewall. It is deployed on KVM hypervisor with 8vCPU and 16G RAM. With such resource I expect it to handle at least 2Gbps throu...
abebeTelus by Frequent Visitor
  • 436 Views
  • 6 replies
in IOS XE, when you configure an unnumbered interface to borrow address from another interface other than loopback, it will not show up in RIB thus is not able to return the traffic. a static route needs to be configured to point to the unnumbered in...
daniel ng by Spotlight
  • 2072 Views
  • 23 replies
Hi , am trying to use vCSR router as vEdge SDWAN for lab practice, but am not able to convert to SDWAN Controller. am using the following IOS XE Version . How can I convert to SDWAN controller mode.  Router#show versionCisco IOS XE Software, Version ...
uni1389 by Level 3
  • 116 Views
  • 1 replies
Hello,I have C8300 router with T1 licence. I am on version 17.14.1a so i have 500mbps aggregate. I upgrade router on recommended version 17.15.4c, and than output of command show version shows: The current crypto throughput level is 2000000 kbps (Agg...
mdzaf by Level 3
  • 277 Views
  • 4 replies
Hi, I'm currently studying or at least trying to study for the CCNA exam and bought a Cisco 1800 series router to play around with and get some real hands on experience.  It seems to mostly work ok but I keep getting an error message, see screenshot ...
glosnick by Visitor
  • 389 Views
  • 6 replies
Hi all, I have a Cisco hosted and managed SDWAN controllers and trying to add up a new router C8200. I am directly connecting internet link on routers which means public IP on interfaces.  system config is good, defined vBond IP manually. interfaces ...
