routing issue between subinterfaces
Hasrat Bhanot
Hello
I created subinterfaces on the cisco router 1900
interface GigabitEthernet0/1.1
description Native_Inside_Data
encapsulation dot1Q 1 native
ip nat inside
ip virtual-reassembly in
interface GigabitEthernet0/1.5
description Inside_Phone_WAN
encapsulation dot1Q 5
ip address 192.168.5.1 255.255.255.0
ip nat inside
i can ping from 1.1 to 1.5, but cannot ping to ip address 192.168.5.5 (end device) from 192.168.1.1 or vice versa
please advise
6 Replies 6
Jon Marshall
Is the trunk from the switch allowing both vlans
Are the clients using the right default gateways
if 192.168.5.5 can ping 192.168.1.1 then check for host firewallls on the end devices.
Jon
192.168.5.5 cannot ping 192.168.1.1 or vice versa , seems routing issue but not sure what route i need to put
subinterfaces can ping each other but cannot end devices
thanks
Have you done a "sh int trunk" on the switch to make sure the trunk is up and running and the vlans are allowed on the link.
Jon
issue resolved
removed this command on 192.168.5.5 port
ip verify unicast source reachable-via
working ok now
Verify the that you don't need a RPF. It's important when you need traffic to come in and out the same interface.
http://www.cisco.com/en/US/docs/ios/12_2/security/configuration/guide/scfrpf.html
Yosh
HTH Regards, Yosh
Hasrat Bhanot
issue resolved
working ok now
