Routing Magic packets
jeff_turl
I am trying to allow magic packets from our management servers to client PCs located over routed links.
The management servers are on addresses 172.22.200.54/16 and 172.22.200.63/16
They are directly connected to a 6500 to vlan 1 (GI 1/30 and GI 2/14)
Interface GI7/5 on the 6500 is a routed interface 172.25.200.213/30 and connects to a remote switch i am trying to send magic packets to.
At the far end, Connected via fibre to GI 7/5 is a 3750, port GI 1/0/1 is configured as a routed port and has address 172.25.200.214/30.
On the 3750 are two vlans one for data (vlan 100) 172.21.20.x/24 and one for voice (vlan 300) 172.18.20.x/24, the default gateway for all traffic is back to the 6500.  All other ports on the 3750 are assigned to vlan 100 and 300 for voice
I am trying to get magic packets (only) to be be routed, as far as i understand they are not routed as they are broadcast traffic.
Where do i need to place the ip helper-address and the ip directed-broadcast?  Here is what i have so far (but doesnt work)
3750:
interface GigabitEthernet1/0/1
description Fibre to 6500
no switchport
ip address 172.25.200.214 255.255.255.252
mls qos trust dscp
interface Vlan100
description DATA VLAN
ip address 172.21.20.254 255.255.255.0
ip helper-address 172.22.200.50
6500:
interface GigabitEthernet7/5
description TTH-SWITCH18
ip address 172.25.200.213 255.255.255.252
ip helper-address 172.21.11.255
wrr-queue bandwidth 50 255
mls qos trust dscp
interface GigabitEthernet1/30
description Management-Server1
switchport
mls qos trust dscp
spanning-tree portfast edge
interface Vlan1
ip address 172.22.1.21 255.255.0.0
no ip redirects
ip pim sparse-dense-mode
standby 1 ip 172.22.1.20
standby 1 priority 120
standby 1 preempt
I first wanted to get the WOL working over the routed ports and then restrict it to only WOL traffic/from management servers, so was planning on including an ACL but havent done this part yet.
Can anyone assist me to get this to work?
Jeff
5 Replies 5
paolo bevilacqua
Gelper address is always configure on the interface that initially received the UDP broadcast.
Also, the the destation port is not one of these forwarded by default, you will need to configure it explicitly.
Paolo, if the helper address goes on the interface that recives the broadcast, in this instance is that vlan1 that would need a helper address specified?
Are you also saying i need to configure an ACL to be able to specify the port used for it to work?
Jeff
smehrnia
Level 7
Level 7
Hey Jeff,
to clarify the scenario, and then help... do you want broadcasts (magic packets) from the Servers reach your client segment and received by clients as broadcast there or u just need one client receive those packets as unicast?
two different approaches
Soroush.
Hope it Helps!
Soroush.
Soroush, i have about 6 client PC's that i need to be able to wake up so i was going to go to use broadcast since it will be the same management servers sending the magic packet, i thought it easier to do it this way.
Jeff
right Jeff, then i think what you need to do is using Multicast helper address.
multicast helper address, captures the broadcast at the origination segment, then convert to multicast, send it to its destination and then again convert it back to broadcast. u need to know what UDP port is in use by the broadcast.
setup a multicast group and use below config as an example for ur network:
** Assuming that u have done the multicast part right, here is what you have to do for below diagram
Server----VLAN1---(6500)--Gi7/5------------Gi1/0/1--(3750)---VLAN100---Client
6500:
interface Vlan1
ip multicast helper-map broadcast 239.10.10.1 120  ---> multicast grp & ACL#
ip pim sparse-mode
exit
access-list 120 permit udp host x.x.x.x any udp 3000 ----> broadcast udp port
ip forward-protocol udp 3000 ----> config right port
3750:
int gi1/0/1
ip pim sparse-mode
ip multicast helper-map 239.10.10.1 172.21.20.255 120 ---> dst broadcast ip & ACL
int vlan 100
exit
access-list 120 permit udp host x.x.x.x any eq 3000
Hope it Helps,
plz Rate helpful posts,
Soroush.
Hope it Helps!
Soroush.
