routing problem
shadowwar9990
dear ,
good day to you
I have  cisco 881 router with 1 wan interface and 4 Lan interface.
wan interface connected with 1 Isp line and used static route and  1 Lan interface connected to another Isp line through ospf and 1 Lan connected to internal network to NVR For CCTV
I have  another 880 cisco router in another place connect via static route for first isp
how can i merge the 2 line isp via ospf to have a total speed for the two line and receive NVR Stream from main 880 router .
my configuration as following
boot-start-marker
boot-end-marker
enable password xxx
no aaa new-model
ethernet lmi ce
no ip domain lookup
ip cef
no ipv6 cef
license udi pid C881-K9 sn xxx
vtp mode transparent
username xxx privilege 15 password xxx
vlan 99,2208
interface FastEthernet0
description to Lan
switchport access vlan 99
no ip address
interface FastEthernet1
description test
no ip address
interface FastEthernet2
no ip address
interface FastEthernet3
switchport access vlan 2208
switchport mode trunk
no ip address
interface FastEthernet4
description Wan
no ip address
duplex auto
speed auto
interface FastEthernet4.3537
encapsulation dot1Q 3537
ip address 10.99.8.2 255.255.255.252
interface Vlan1
no ip address
interface Vlan99
ip address 10.8.99.1 255.255.255.0
interface Vlan2208
ip address 10.199.8.1 255.255.255.252
ip ospf network point-to-point
router ospf 1
network 10.8.99.1 0.0.0.0 area 0
network 10.199.8.1 0.0.0.0 area 0
ip forward-protocol nd
no ip http server
no ip http secure-server
ip route 10.7.99.0 255.255.255.0 10.99.8.1
ip route 10.10.11.0 255.255.255.0 10.99.8.1
control-plane
mgcp behavior rsip-range tgcp-only
mgcp behavior comedia-role none
mgcp behavior comedia-check-media-src disable
mgcp behavior comedia-sdp-force disable
mgcp profile default
line con 0
password xxx
logging synchronous
no modem enable
line aux 0
line vty 0 4
privilege level 15
password xxx
login local
transport input telnet
scheduler allocate 20000 1000
8 Replies 8
 Do you have direct connection between those two routers?
hi
no, each router in a bank branch and no direct coonection
Then I dont believe is possible to merge. If you had direct connection between router, you could create a neighborshit between using OSPF and considering you already have OSPF with one of the ISP, this router could load sharing the traffic netween those two neighbors
 But, if you have two independent routers connect to differents ISP, is not possible.
i think that one branch have 2 isp line with speed 2 ,2 mbp and the other branch has 1 isp line with speed 2 mbp.
and they have 1 same isp connection for 1 line  through ospf .
so in this case how can i merge the 2 isp line speed in the first branch and reach An internal NVR for CCTV in the other branch?
It is a bit confuse and seems to me not possible. Can you make a simple topology just to have a better understanding?
Do you have rough Diagram of this network ? is the ISP Link is Internet ?
how is this branches connected ? over internet ?
what you mean merge these 2 Links ?
BB
connected through VPN connection , as following diagram i have 2 isp on one side so i want to merge their speed and share NVR device in internal network  with the other main branch router  via Ospf
