Routing Protocols.
azibnaseem
Dear CISCO Team,
I need to know that can I run multiple IGP on same router?
Regards'
Azib Naseem.
2 Accepted Solutions
And you can also have more instance of the same routing protocol (OSPF and EIGRP only)
enrico.
Please mark a correct answer.
Deepak Kumar,
Don't forget to vote and accept the solution if this comment will help you!
5 Replies 5
Pawan Raut
Level 4
Level 4
Yes You can. Also you can do mutual redistribute the IGP routes
enrico.
Deepak Kumar
Hi Azib,
Yes you can and you can choose which IGP protocol will choose to routing.
Deepak Kumar
www.deepuverma.in
Deepak Kumar,
azibnaseem
Dear All,
Thanks for the reply. I have configured multiple IGP's on same router and both are working well.
Deepak Kumar,
