Routing Question - What Am I Missing
js358
Hello All:
Have a 3660 with 3 T1 multilink line. Presently, have one internal subnet using this router for internet.
Have FA0/1 10.0.2.1 with IP nat inside routing out 0.0.0.0 0.0.0.0 153.x.x.x
This is 2x segment gateway
This is working fine.
What I am trying to do is add another subnet 3x and firewall to use this router as well.
3660 - FA1/2 65.x.x.1 attached to WAN port on Firewall 65.x.x.2.
Firewall LAN 10.0.3.1 - gateway for 3x
I can get out from inside to internet but I cannot run any services behind firewall such as DNS and have them accessible from internet, despite correct rules on firewall.
I can ping from the firewall (65.x.x.2) to FA1/1 (65.x.x.1) on the router but cannot ping from FA1/1 to firewall.
Any ideas as to why this is. If I sh arp on router, it sees the FW interface 65.x.x.2
ANy help would be appreciated.
You should be able to ping the firewall ipaddress from the router. Can you share the specific rules of your firewall related to Inbound traffic from the router and rules related to DNS.
