Showing results forĀ
Search instead forĀ
Did you mean:Ā
[Routing] - Routing issue at Cisco 2951 router
We have a hosting/housing supplier that provides us connecivity through two links and we are using HSRP.
Las week after rebooting our router, it stopped reaching specifically the HSRP address at the suppliers routers, but still can reach the real addresses at the equipments:
RCURST08#ping  10.216.16.190
Type  escape sequence to abort.
Sending 5, 100-byte ICMP Echos to 10.216.16.190,  timeout is 2 seconds:
U.U.U
Success rate is 0 percent  (0/5)
RCURST08#
RCURST08#ping 10.216.16.189
Sending 5, 100-byte ICMP Echos to 10.216.16.189,  timeout is 2 seconds:
Success rate is 100 percent (5/5), round-trip  min/avg/max = 1/1/4 ms
RCURST08#ping 10.216.16.188
Sending 5, 100-byte ICMP Echos to 10.216.16.188,  timeout is 2 seconds:
RCURST08#
Our router informations:
Anterior:
ip route  10.216.17.0 255.255.255.0 10.216.16.190 name TIVIT
Atual:
ip route  10.216.17.0 255.255.255.0 10.216.16.188 name TIVIT
RCURST08#sh ip route  10.216.17.0
Routing entry for 10.216.17.0/24
  Known via "static",  distance 1, metric 0
  Routing Descriptor Blocks:
  *  10.216.16.188
      Route metric is 0, traffic share count is  1
RCURST08#
RCURST08#sh ip route  10.216.16.190
Routing entry for 10.216.16.176/28
  Known via "connected",  distance 0, metric 0 (connected, via interface)
  * directly connected, via BVI11
RCURST08#
RCURST08#sh ip route 10.216.16.188
RCURST08#sh ip route 10.216.16.189
RCURST08#
RCURST08#sh run int bvi11
Building  configuration...
Current configuration : 211  bytes
interface BVI11
description Intercon_Softway_TIVIT Vlan.11
ip address 10.172.65.101  255.255.255.252 secondary
ip address 10.251.127.209 255.255.255.252  secondary
ip address 10.216.16.177  255.255.255.240
end
RCURST08#
RCURST08#sh int bvi11
BVI11 is up, line protocol is up
  Hardware is BVI, address is 588d.095d.35a2 (bia 0000.0000.0000)
  Description: Intercon_Softway Vlan.11
  Internet address is 10.216.16.177/28
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 5000 usec,
  Keepalive set (10 sec)
  Last input 2d20h, output never, output hang never
  Queueing strategy: fifo
  Output queue: 0/0 (size/max)
  5 minute input rate 234000 bits/sec, 118 packets/sec
  5 minute output rate 193000 bits/sec, 116 packets/sec
     22953711 packets input, 6005157828 bytes, 0 no buffer
     Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
     0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
     24760494 packets output, 3518436390 bytes, 0 underruns
     0 unknown protocol drops
RCURST08#
RCURST08#sh run int g0/2
Current configuration : 79 bytes
interface GigabitEthernet0/2
no ip address
duplex auto
speed auto
end
RCURST08#sh run int g0/2.11
Current configuration : 80 bytes
interface GigabitEthernet0/2.11
encapsulation dot1Q 11
bridge-group 11
end
RCURST08#sh int g0/2
GigabitEthernet0/2 is up, line protocol is up
  Hardware is PQ3_TSEC, address is 588d.095d.35a2 (bia 588d.095d.35a2)
  MTU 1500 bytes, BW 1000000 Kbit/sec, DLY 10 usec,
  Encapsulation 802.1Q Virtual LAN, Vlan ID  1., loopback not set
  Full-duplex, 1000Mb/s, media type is RJ45
  output flow-control is unsupported, input flow-control is unsupported
  Last input 00:00:00, output 00:00:00, output hang never
  Output queue: 0/40 (size/max)
  5 minute input rate 252000 bits/sec, 160 packets/sec
  5 minute output rate 217000 bits/sec, 140 packets/sec
     30357690 packets input, 6516602290 bytes, 0 no buffer
     Received 6369564 broadcasts, 0 runts, 0 giants, 0 throttles
     0 watchdog, 4446773 multicast, 0 pause input
     24955712 packets output, 3662033203 bytes, 0 underruns
     3 unknown protocol drops
     0 lost carrier, 0 no carrier, 0 pause output
RCURST08#
RCURST08#sh int g0/2.11
GigabitEthernet0/2.11 is up, line protocol is up
  Encapsulation 802.1Q Virtual LAN, Vlan ID  11.
RCURST08#
RCURST08#sh ver
Cisco IOS Software, C2951 Software (C2951-UNIVERSALK9-M), Version 15.0(1)M4, RELEASE SOFTWARE (fc1)
Copyright (c) 1986-2010 by Cisco Systems, Inc.
Compiled Thu 28-Oct-10 18:58 by prod_rel_team
ROM: System Bootstrap, Version 15.0(1r)M6, RELEASE SOFTWARE (fc1)
RCURST08 uptime is 3 days, 10 hours, 19 minutes
System returned to ROM by reload at 01:42:04 UTC Fri May 6 2011
System restarted at 01:43:29 UTC Fri May 6 2011
System image file is "flash0:c2951-universalk9-mz.SPA.150-1.M4.bin"
Last reload type: Normal Reload
Last reload reason: Reload Command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco CISCO2951/K9 (revision 1.1) with 1003520K/45056K bytes of memory.
Processor board ID FTX1447A0MH
4 Gigabit Ethernet interfaces
4 Serial(sync/async) interfaces
1 terminal line
1 Virtual Private Network (VPN) Module
DRAM configuration is 72 bits wide with parity enabled.
255K bytes of non-volatile configuration memory.
500472K bytes of ATA System CompactFlash 0 (Read/Write)
License Info:
License UDI:
Device#   PID                   SN
*0        CISCO2951/K9          FTX1447A0MH
Technology Package License Information for Module:'c2951'
Technology    Technology-package          Technology-package
              Current       Type          Next reboot
ipbase        ipbasek9      Permanent     ipbasek9
security      securityk9    Permanent    securityk9
uc            None          None          None
data          None          None          None
RCURST08#
Detail is that we have HSRP at our internal firewalls that communicates with this router through other interface and is fine.
If someone has some experience or idea of what could be happenning?
Rds,
Luiz
4 Accepted Solutions
Richard Burts
Luiz
It would perhaps be helpful if you would post the output of show arp from the router. From the symptoms you describe I suspect that there are arp entries for 188 and 189 but not for 190.
Rick
Rick
Luiz
Thanks for posting the output of show arp as I asked. I am surprised to see that there is an arp entry for the .190 address. I notice that the same MAC address is also in the arp table for addresses 178, 179, 180, 183. Do you know anything about those addresses? Are those addresses pingable?
Rick
Rick
Luiz
Thank you for the additional information. It is quite helpful. It shows what is preventing access to the .190 address though it does not show what the underlying cause of the problem is.
First let us look at the arp table from your previous post:
Internet  10.216.16.178          35   000d.bcb9.0c60  ARPA   BVI11
Internet  10.216.16.179          25   000d.bcb9.0c60  ARPA   BVI11
Internet  10.216.16.180          21   000d.bcb9.0c60  ARPA   BVI11
Internet  10.216.16.183          19   000d.bcb9.0c60  ARPA   BVI11
Internet  10.216.16.190          62   000d.bcb9.0c60  ARPA   BVI11
The important entry is the one for 190 but I include the others because they show the same MAC address. So your router believes that the MAC address associated with .190 is 000d.bcb9.0c60.
Then let us look at the entry on the ISP router:
Internet  10.216.16.190           -   0000.0c07.ac01  ARPA   FastEthernet0/0
so on the ISP router the MAC address is 0000.0c07.ac01. This is a normal MAC address for HSRP and it is different from the MAC that your router is using.
So your router can not access .190 because it is learning the wrong MAC address for 190.
It is not clear from what we know so far what is causing the wrong MAC to be learned. Is 000d.bcb9.0c60 by any chance the MAC associated with a firewall or something like that?
Rick
Rick
Luiz
Some device other than the ISP router is responding to the ARP request for the .190 address and this is what is causing the problem. If you can find what device has MAC  000d.bcb9.0c60 then you may be able to fix this problem.
If the connections are in a 2950 switch then you should be able to look into the mac address table and find what port has MAC  000d.bcb9.0c60 and then find what device is connected on that switch port.
Rick
Rick
10 Replies 10
Calin C.
Level 5
Level 5
DId you checked with your provider that the HSRP configuration is fine on their side?
A "show standby brief" on their side could clarify if everything is fine.
How is your physical connection with the provider done? Two interfaces bridged? I see only one interface and one subinterface in your output.
Cheers,
Calin
Richard Burts
Luiz
Rick
Rick
At supplier they say that is everything ok, and at my router here is the show ARP:
RCURST08#sh arp
Protocol  Address          Age (min)  Hardware Addr   Type   Interface
Internet  10.172.65.101           -   588d.095d.35a2  ARPA   BVI11
Internet  10.172.65.102         120   000d.bcb9.0c60  ARPA   BVI11
Internet  10.216.16.177           -   588d.095d.35a2  ARPA   BVI11
Internet  10.216.16.188         120   001e.be17.0818  ARPA   BVI11
Internet  10.216.16.189         120   0024.97ea.8088  ARPA   BVI11
Internet  10.251.127.209          -   588d.095d.35a2  ARPA   BVI11
Internet  10.251.127.210        120   0064.405b.d6b0  ARPA   BVI11
Internet  172.25.121.9            -   588d.095d.35b8  ARPA   GigabitEthernet2/0
Internet  172.25.248.113        158   0000.0c07.ac06  ARPA   GigabitEthernet0/0
Internet  172.25.248.114         88   0030.8040.6aa2  ARPA   GigabitEthernet0/0
Internet  172.25.248.115        142   0030.8047.d9a2  ARPA   GigabitEthernet0/0
Internet  172.25.248.116        218   00e0.1e8d.fab0  ARPA   GigabitEthernet0/0
Internet  172.25.248.117          -   588d.095d.35a0  ARPA   GigabitEthernet0/0
Internet  172.25.248.118        222   0016.c724.4521  ARPA   GigabitEthernet0/0
RCURST08#
Luiz
Rick
Rick
I'm looking but they belong to the range and are not active.
Other strange thing is about the Int BVI11 that is showing MAC as 0:
I've tried to  use the MAC address command with the one of Giga inteface, but it seems not to recognize:
Could this be a signal of problem?
Rds,
Luiz
These are information at SP main router that answers for HSRP:
Renault-Principal#sho arp
Internet  10.216.16.177          18   588d.095d.35a2  ARPA   FastEthernet0/0
Internet  10.216.16.188           -   001e.be17.0818  ARPA   FastEthernet0/0
Internet  10.216.16.189           1   0024.97ea.8088  ARPA   FastEthernet0/0
Renault-Principal#sho standby
FastEthernet0/0 - Group 1
  State is Active
    131 state changes, last state change 5w1d
  Virtual IP address is 10.216.16.190
  Active virtual MAC address is 0000.0c07.ac01
    Local virtual MAC address is 0000.0c07.ac01 (v1 default)
  Hello time 3 sec, hold time 10 sec
    Next hello sent in 1.836 secs
  Preemption enabled, delay min 10 secs
  Active router is local
  Standby router is 10.216.16.189, priority 95 (expires in 7.208 sec)
  Priority 100 (default 100)
    Track interface Serial0/0/0 state Up decrement 10
  IP redundancy name is "hsrp-Fa0/0-1" (default)
     10.0.0.0/8 is variably subnetted, 5 subnets, 5 masks
C       10.216.16.176/28 is directly connected, FastEthernet0/0
S       10.216.17.0/24 is directly connected, Serial0/0/0
S       10.221.0.0/16 [1/0] via 10.216.9.41
C       10.216.9.41/32 is directly connected, Serial0/0/0
C       10.216.9.40/30 is directly connected, Serial0/0/0
S*   0.0.0.0/0 [1/0] via 10.216.16.177
Luiz
Rick
Rick
The point is that they are connected at layer 2, at same Vlan in a 2950 switch.
Luiz
Rick
Rick
Using the sh mac-address at switch found this address at one other supplier's router, that ha been working for the last 3 years without problem en know decided to call attentiom. Apparentally no bug or problem or even config mistake.
Good case to study deeper.
