Routing with VLAN
Portus92
I have a Cisco 897 VA.
The WAN interface is connected to my pfSense (LAN 10.0.0.0/24, the pfSense address is 10.0.0.1).
On my router, the WAN interface IP address is 10.0.0.90. I would like to have two VLAN (10 and 20) with an Internet access (with the default gateway 0.0.0.0 0.0.0.0 10.0.0.1).
Here is my Cisco config :
ip dhcp excluded-address 10.0.10.1 10.0.10.10
ip dhcp excluded-address 10.0.20.1 10.0.20.10
ip dhcp pool VLAN10
 network 10.0.10.0 255.255.255.0
 dns-server 10.0.10.1
 default-router 10.0.10.1
ip dhcp pool VLAN20
 network 10.0.20.0 255.255.255.0
 default-router 10.0.20.1
 dns-server 10.0.20.1
ip domain name home.com
ip name-server 10.0.0.1
ip name-server FE80::1:1
ip cef
ipv6 unicast-routing
ipv6 cef
vtp mode transparent
vlan 10,20
interface GigabitEthernet0
 switchport trunk allowed vlan 1,10,20,1002-1005
 no ip address
interface GigabitEthernet1
 no ip address
interface GigabitEthernet2
 switchport access vlan 10
 no ip address
interface GigabitEthernet3
 no ip address
interface GigabitEthernet4
 no ip address
interface GigabitEthernet5
 no ip address
interface GigabitEthernet6
 no ip address
interface GigabitEthernet7
 no ip address
interface GigabitEthernet8
 ip address 10.0.0.90 255.255.255.0
 duplex auto
 speed auto
 ipv6 address x:x:x:x::1/128
 ipv6 enable
interface Vlan1
 no ip address
interface Vlan10
 ip address 10.0.10.1 255.255.255.0
interface Vlan20
 ip address 10.0.20.1 255.255.255.0
ip route 0.0.0.0 0.0.0.0 10.0.0.1
ip ssh version 2
ipv6 route ::/0 GigabitEthernet8 FE80::1:1
I connected a PC (10.0.10.11) on GE2, but ping to 10.0.0.1 (pfSense) is not working.
I can ping 10.0.10.1 with an other PC, but I can't ping 10.0.10.11.
There is a static route in my pfSense too :
Thanks a lot for your help.
5 Replies 5
Hello
Turn off any software firewall on pc 10.0.10.11 and test again
Kind Regards
Paul
Check trace, also use an ACL and count and check if you are getting any reply for the ICMP packet.
Please share a network diagram if you have one.
Please do not hesitate to click the STAR button if you are satisfied with my answer.
Hi, here is a little network diagram :
I tried to deactivate the firewall on the PC, but no effect.
With ACL (applied on VLAN 10), ping to 10.0.10.11 doesn't match :
Extended IP access list 110
    10 permit icmp any host 10.0.10.11
    20 permit icmp any host 10.0.10.1 (37 matches)
    30 permit ip any any (5442 matches)
Thank you.
what is connected to interface GigabitEthernet0 ?
Make sure your pfsense does NAT for the new networks, or use double NAT on the Cisco (changes marked in bold):
ip dhcp pool VLAN10
--> dns-server 8.8.8.8
ip dhcp pool VLAN20
ip cef
ipv6 cef
vlan 10,20
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
no ip address
--> ip nat outside
duplex auto
speed auto
ipv6 enable
interface Vlan1
no ip address
interface Vlan10
--> ip nat inside
interface Vlan20
--> ip nat inside
--> ip nat inside source list 1 interface GigabitEthernet8 overload
--> access-list 1 permit 10.0.10.0 0.0.0.255
--> access-list 1 permit 10.0.20.0 0.0.0.255
ip ssh version 2
There is nothing connected to GE0.
The PC is connected to GE2.
With ip nat it works, thanks ! I'm not sure I fully understand why.
There is just one problem, I can't ping 10.0.10.1 or 10.0.10.11 from another PC.
With the PC on GE2, I can ping 10.0.0.1 and all the other devices on the network :
