Routuing
Mlex1
Hello every one i want configure this three router, every router in different subnet, how i achieve connectivity. thank in advance
i know one solution VRF but i don't need currently use vrf, i want only connectivity
config from R2
interface GigabitEthernet0/0
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.10
encapsulation dot1Q 10
ip address 192.168.10.2 255.255.255.0
config from R3
no ip address
duplex auto
speed auto
media-type rj45
interface GigabitEthernet0/0.30
encapsulation dot1Q 30
ip address 192.168.30.3 255.255.255.0
config from R1
no ip address
duplex auto
speed auto
media-type rj45
ip address 192.168.10.1 255.255.255.0
ip address 192.168.30.1 255.255.255.0
config from SW
vlan 10
vlan 30
switchport trunk allowed vlan 10-30
switchport mode trunk
negotiation auto
interface GigabitEthernet0/1
switchport access vlan 10
switchport mode access
negotiation auto
interface GigabitEthernet0/2
switchport access vlan 30
negotiation auto
Wish all the best
You use subinterface in R3 and R2 but use access port in SW
This mismatch
Router send tag with vlan and sw send untag frame
So ypu need to make Sw to R2 and R3 trunk not access port
MHM
9 Replies 9
Using ospf IGP
Perfix connect to R1 put it in ospf area 0
Vlan connect R1 to R2 put it into area 1
Vlan connect R1 to R3 put it into area 2
prefix connect to R2 in area1
Prefix connect to R3 in area2
MHM
it's not working because i can't ping, routers can't see each other
Wish all the best
Do below change in SW
switchport trunk allow  vlan 10
negotiation auto
switchport trunk allow vlan 30
negotiation auto
MHM
appreciate your support didn't understand you
Wish all the best
This mismatch
MHM
thanks it's working
Wish all the best
You should be able to configure a routing protocol to meet your needs. YOU can use OSPF o EIGRP for simplicity.
If you just need basic connectivity, you can use the below commands on all 4 devices. Make sure ip routing is enabled on the switch.
router eigrp 1
network 0.0.0.0 255.255.255.255
or
router ospf 1
network 0.0.0.0 255.255.255.255 area 0
-David
this step i done already don't working if you want i can share configure
ip routing enable on switch
Wish all the best
Make sure you also create VLAN 20 on the switch. If you want, you can share configuration of all 4 devices here to help us troubleshoot better.
