RV340 Dual Wan Router
SBT80013
I have a Dual WAN setup and configured in the Multi-WAN page for load balancing between the two at 50% each and it works.
However I am running into a problem in creating records in the Policy Binding Table. I am able to add a record, however the Apply button is disabled and am unable to save the configuration. The reason I need this is to route requests for specific IPs through only one of the WANs.
Tried several times including rebooting - but to no avail. If anyone has solved this - will be highly appreciated.
Firmware version is 1.0.03.20
2 Accepted Solutions
amikat
In my view you should input your "Destination IP" address in the format as "203.53.8.130/32". Can you please try.
Best regards,
Antonin
Thank you!
Worked perfectly, the Apply button got enabled and is routing the specific IP via WAN 2
10 Replies 10
what are you actually entering, can you post a screenshot ?
Attached image - I am able to add a routing policy - but unable to save it.
 Thanks for the quick reply - attached here
in the 'Destination IP' field, enter the subnet mask as well:
203.53.8.130/24
Thanks.
Did that - but the Apply button is still disabled.
I am looking at the user guide:
Step 8 Click Apply.
Some service providers do not allow to ping the default gateway. Please choose a valid remote host to detect
the network connectivity or simply disable the detection. Otherwise, the traffic will not be forwarded by the
device.
Thanks - but was held up.
The Apply button is common for the WAN load balancing / failover settings and for policy routing.
I have google.com as the remote host and I can see from the router port statistics that traffic is distributed between the WANs.
The moment I start to configure a routing policy, the Apply button gets disabled - and there is no option to save the policy.
amikat
Best regards,
Antonin
Thank you!
Interesting. And really good to know, as this is not documented anywhere...
