RV340 not releasing any IP Address for new devices
AstralSkye
I've recently started having issues with my router not releasing any IP Addresses for anything new that connects. I have to type in every new device with a Static IP or it doesn't connect at all.
I've restarted the RV340 a number of times already and even did a saved configuration from a month ago. Starting over will soon be a last resort but it will take our business down for a bit and wanted to avoid it. And the issue will just keep coming back if I can't find the solution.
I have the DHCP range open from .100-.249. We have barely 80 devices in use at one time and around 60 of those are .1-.99.
I go into DHCP Bindings and it only shows about 10 devices on that list.
I have multiple routers on our network in AP or Bridge mode. Is it possible another router is saving IP Addresses and making the RV340 see them in use?
I'm at a loss for what to do
balaji.bandi
is RV not offering New DHCP?
can you post the configuration screenshot?
do you see DHCP offerings? how many inactive? what is the lease time setup?
BB
which firmware version are you running ? Make sure you have the latest release, 1.0.03.19, installed.
