Routing and SD-WAN
Labels
I have a C8000v SDWAN edge running IOS-XE 17.15.3a, it acts as a transit hub for the SDWAN sites to connect to a PaloAlto firewall. It is deployed on KVM hypervisor with 8vCPU and 16G RAM. With such resource I expect it to handle at least 2Gbps throu...
abebeTelus by Frequent Visitor
  • 396 Views
  • 4 replies
Hello,I have C8300 router with T1 licence. I am on version 17.14.1a so i have 500mbps aggregate. I upgrade router on recommended version 17.15.4c, and than output of command show version shows: The current crypto throughput level is 2000000 kbps (Agg...
mdzaf by Level 3
  • 260 Views
  • 4 replies
Hi, I'm currently studying or at least trying to study for the CCNA exam and bought a Cisco 1800 series router to play around with and get some real hands on experience.  It seems to mostly work ok but I keep getting an error message, see screenshot ...
glosnick by Visitor
  • 362 Views
  • 6 replies
Hi all, I have a Cisco hosted and managed SDWAN controllers and trying to add up a new router C8200. I am directly connecting internet link on routers which means public IP on interfaces.  system config is good, defined vBond IP manually. interfaces ...
Hi,I was reading about MX utilization, and splitting load between the two MXs by creating active/active scenario.The above article say that the traffic can be split, for example, between two MXs - one for AutoVPN, and the other for internet-bound tra...
iores by Level 6
  • 744 Views
  • 6 replies
Hello all,Does anyone know when Meraki are planning to fix the false positives in the event logs for IP conflict Source IP and/or VLAN mismatch? We're still seeing this in our logs on a daily basis and we can't tell any genuine issues apart from the ...
JonP by Level 3
  • 4801 Views
  • 5 replies
