Second PVC on Cisco 867 Router Setup
Tim Roelands
For VOIP purposes I need to setup a second PVC (ATM PPPoA) witin my Cisco 867 config. My provider provide me with two ATM connections (using the same line), but the problem is I can't find a good setup guide for this issue. Biggest problem...Iam a GUI addict, (Cisco Configuration Professional), but I can't find a way to set it up by using CCP. Meantime I did find a Cisco page about my issue:
http://www.cisco.com/en/US/products/hw/routers/ps380/products_configuration_example09186a0080093e4b.shtml
But that does not bring me any further. Anyone got some info for setting this up the rigjht way? Here's my running config:
Building configuration...
Current configuration : 3690 bytes
version 15.1
no service pad
hostname cisco800
boot-start-marker
boot-end-marker
aaa new-model
aaa authentication login default local
aaa session-id common
memory-size iomem 10
crypto pki trustpoint TP-self-signed-3977281076
enrollment selfsigned
subject-name cn=IOS-Self-Signed-Certificate-3977281076
revocation-check none
rsakeypair TP-self-signed-3977281076
crypto pki certificate chain TP-self-signed-3977281076
certificate self-signed 01
  30820240 308201A9 A0030201 02020101 300D0609 2A864886 F70D0101 04050030
  31312F30 2D060355 04031326 494F532D 53656C66 2D536967 6E65642D 43657274
  69666963 6174652D 33393737 32383130 3736301E 170D3032 30333031 30303235
  31395A17 0D323030 31303130 30303030 305A3031 312F302D 06035504 03132649
  4F532D53 656C662D 5369676E 65642D43 65727469 66696361 74652D33 39373732
  38313037 3630819F 300D0609 2A864886 F70D0101 01050003 818D0030 81890281
  8100BA91 F2BABFB1 2C3FBFE6 0413C374 B8CEC0B7 165EE17B 7BA146B5 01E75652
  C80AD669 A5F7E426 23CC692E 58D174B0 CDD1AF57 A6E9BE05 2465771C DCF29C4A
  C3C3532A 62DDE538 6BD98D81 4B4F6860 BCEA0BBC D099DE4A 34185631 7D202243
  4DC86748 DB5FF94B ADF0963F CCA679F8 F95D59CA 9636B17D 713E4F57 84AF788C
  FD5F0203 010001A3 68306630 0F060355 1D130101 FF040530 030101FF 30130603
  551D1104 0C300A82 08636973 636F3830 30301F06 03551D23 04183016 8014050A
  9AD2CECB BBF39F15 92DE6655 E53B6256 F4EF301D 0603551D 0E041604 14050A9A
  D2CECBBB F39F1592 DE6655E5 3B6256F4 EF300D06 092A8648 86F70D01 01040500
  03818100 673A244A 11AC5D6F 45A7D03D E3789163 8A4F5A40 6EAC256C 35968CB8
  B09A8EC2 2C124DC1 A7951754 5BBCB7E6 D96A2618 06A972EB 405A59F3 5ED609CC
  2805A2AA FFA6FFDF E158B7A7 DF8809F3 C438946F D10C0B71 F64DC457 00D811CE
  1A116DA7 8EE91B17 3216B01F C25C4B26 F2F5633C C00D6FD3 AB0F55DA 0423C10B 005670C8
   quit
ip source-route
ip dhcp excluded-address 192.168.10.1 192.168.10.99
ip dhcp excluded-address 192.168.10.151 192.168.10.254
ip dhcp pool Pool1
   import all
   network 192.168.10.0 255.255.255.0
   dns-server 213.144.235.1 213.144.235.2
   default-router 192.168.10.200
ip cef
license udi pid ****
archive
log config
  hidekeys
username admin privilege 15 secret 5 ******
interface ATM0
no ip address
no atm ilmi-keepalive
interface ATM0.1 point-to-point
pvc 1/99
  encapsulation aal5mux ppp dialer
  dialer pool-member 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 192.168.10.200 255.255.255.0
ip nat inside
ip virtual-reassembly
interface Dialer0
ip address negotiated
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication chap pap callin
ppp chap hostname ******
ppp chap password 0 ******
ppp pap sent-username ***** password 0 *****
ip forward-protocol nd
ip http server
ip http authentication local
ip http secure-server
ip http timeout-policy idle 60 life 86400 requests 10000
ip nat inside source list 1 interface Dialer0 overload
access-list 1 remark INSIDE_IF=Vlan1
access-list 1 remark CCP_ACL Category=2
access-list 1 permit 192.168.10.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
transport input all
scheduler max-task-time 5000
end
5 Replies 5
paolo bevilacqua
You CANNOT do this with any of the pitiful GUIs Cisco provides.
No problem using CLI.
Oke, thanks. Problem is that the URL I mentioned does not provide any command instructions to use in CLI mode. I anyone has any suggestions, please let me know!
There are no additional instructions needed. Configure additional PVCs just like the first is done, or with the necessary variations.
Problem is, I configured the first PVC using the GUI, now I need to switch to CLI mode to configure the second PVC....I don't know how
You can either study the documentation, or engage someone to make the configuration for you.
