Secondary route
We have a router (ROUTER1) that is managed by our software provider that creates a site to site VPN
connection. The router has an internal and external IP and we have the external address setup in BGP
as a network. This setup allows us to provide online services.
We have created a DR site and have a secondardy router (ROUTER2) setup there. I need to be able to
have all traffic go to ROUTER2 if the ROUTER1 is unable to make a connection or in a worst case
scenario, if that main location no longer exists.
As an example:
ROUTER1 IP: 10.20.102.125
ROUTER2 IP: 10.20.128.125
Then end IP address the routing needs to route to: 10.15.1.199
Currently, we have that setup as a network in BGP. We also have a static route setup at our main
location as such:
IP ROUTE 10.15.1.0 255.255.255.0 10.20.102.125
Since we have multiple sites (10 +), what would be the best way to provide the required failover?
Hope this makes sense.
Chris
jj27
If I understand what you want to do correctly, you want to advertise networks out of the main site and the DR site in BGP.  If the main site goes down, you want all traffic to be redirected to the DR site.  If that is the case, advertise the same networks out of both routers (ROUTER1 and ROUTER2) in BGP, but use a route-map to as-path prepend the DR site a couple of times so the preferred route is going out of the main store, when that connection goes down the routes will go across to the DR site.
For example:
ip access-list standard local-site-networks
permit 10.10.10.0 0.0.0.255
ip access-list standard remote-site-networks
permit 10.10.20.0 0.0.0.255
router bgp 64722 (change your AS number here, and in the route-map below)
   neighbor 10.200.63.66 route-map BGP-to-ATT out
route-map BGP-to-ATT permit 10
  match ip address local-site-networks
route-map BGP-to-ATT permit 20
  match ip address remote-site-networks
  set as-path prepend 64722 64722 64722 64722
If that's not what you want to do, you can also use IP SLAs to do tracked routes for the 10.15.1.0/24 network.  If you run EIGRP between all of the remote stores and redistribute static into EIGRP, if the tracked route fails, the secondary route will install itself into the table and populate across EIGRP to all routers.
