Selection of router model
farhan_p2000
I am looking for an appropriate router model for our branch office.
Can anyone suggest appropriate models which can meet branch office requirements.
I think modular routers would be a better choice than integrated services routers.
mheusinger
Level 10
Level 10
You might want to use the "Cisco Product Advisor"
http://tools.cisco.com/GCT/PCTPST/en/US/adirect/cisco?cmd=advisor&dummy=1&external.findCompare=Find&begin=yes&startstate=answer_Find-Compare_Find
It will ask you several questions regarding your requirements and suggests the most relevant product.
Another option is the "Solution Finder for Modular Routers"
http://www.cisco.com/pcgi-bin/finder/msbsearch.pl
Regards, Martin
spremkumar
Level 9
Level 9
Hi Farhan
The router model also depends on the kinda connectivity you are going to have in your branch office.
Different models of ISR supports different cards and the mode of connectivity decides the type of card to be in place on the router..
regds
mheusinger
Level 10
Level 10
Regards, Martin
swapniljain
cisco 1841 are ideal for branch office requirements. but u should look what exactly u need
Swapnil Jain
