Serial interface problem..
xtam1
Hi All,
I have a problem in a leased line, but while troubleshooting with the teleco if found out that when the make a HW loop i notice that my serial interface showing the following:
Serial13/1/7:0 is up, line protocol is down (looped) while using PPP encapsulation, so what is the problem?!!!
Below is the output for sh interface serial:
Hardware is Multichannel E1
MTU 300 bytes, BW 128 Kbit, DLY 20000 usec,
Encapsulation PPP, crc 16, Data non-inverted
Keepalive set (10 sec)
LCP REQsent
Closed: CDPCP
Last input 00:00:00, output 00:00:00, output hang never
Last clearing of "show interface" counters 00:00:14
Queueing strategy: fifo
Output queue :0/40 (size/max)
14 packets input, 224 bytes, 0 no buffer
Received 0 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort
14 packets output, 224 bytes, 0 underruns
0 carrier transitions no alarm present
Timeslot(s) Used:UNFRAMED, transmit delay is 0 flags
Regards..
5 Replies 5
anuragv
I belive this is the case with ppp encapsulation . In HDLC it will show even line protocol up when looped. Also for 14 seconds the loop statistics aregood. Try for more time and see what stats are there.
regards
Aasheesh GUpta
Dear Aasheesh,
loop With HDLC it is Up Up (looped), my problem is that i can not get this link to be Up Up, it is always Up Down even without the loop, i am forced to use PPP, are there any suggestions?!!
Reagrads..
pciaccio
Level 4
Level 4
The looped status is telling you that the interface sees a loopback facing it. The loop can be located anywhere in the path of the line. The first thing I would do is check your first point in house and verify the loop is not coming from you. Once you prove yourself good, Then verify that the loop is not coming from the remote site office.If you still have not found the loop then you can scream at the carrier to check their line.
Absolutely. PPP uses a pseudo-random magic number to identify its own LCP setup requests. If it sees setup requests coming from itself it will report a loop. My experience is that if PPP says there's a loop, you can trust it.
Yes there is a loop, but my question was why i see the interface status as Up Down even in the presence of the loop?!!!
