Serial Line Problem
DazWilliams
We have a 2Mbit leased line between two of our sites. In the last day or two we have been experiencing thousands of frame and CRC errors on one of our serial interfaces (X21). Today our leased line providers did and end to end test of the line and found no problems. The router is a 1721 with a WIC card. The router is showing no other problems. Is the WIC card likely to be the problem and apart from replacing it is there any other information I could gather from the router that would confirm this?
TIA
Daz
7 Replies 7
desai.jaideep
Level 5
Level 5
(1)You can check the routers back-to-back using DTE-DCE cable.This will eliminate the carrior with the modems.
(2)You can take loopbacks from your telco and then check on the router.You should be able to ping your serial ip in looped mode.(set encap to hdlc)
Hope it helps.Pls revert back if u have more questions
JD
Problem is the sites are 80 miles apart and because we have limited connectivity, its better than none, I've already ordered a new WIC-2T because we have another leased line out to the internet, so I would need a second WIC anyway. I suppose its just reassurance that its likely to be the WIC, fingers crossed as I've just commited ?500 to it with the cables!
To a point you can confirm it is the wic by placing a loop on the circuit at the csu/dsu toward the router.
This would mean all you had was wic-cable-csu/dsu-loop
If you own the CSU/DSU you can do this with software and can place it on the data side or line side of the csu/dsu. This would help to eliminate the csu/dsu. Otherwise you can loop it with a cable. It could still be the cdu/dsu and I tend to suspect those more than wic cards.
I did originally suspect the DSU but the engineers did there end to end test from our side of the dsu's, basically connected to the x21 interface on the dsu's at either end and plugged a gadget into it that then ran for about 30 mins
I believe they have done BERT test which is standard for testing a lease-line.
I have following queries:
(1)The did a 30. min. test. What is the frequency of your errors?Are the errors comming in that time?If u do "clear counters" and check for a hr,what are the errors and CRCs comming?
JD
I suggest to have the loopback test too, it can also elimiate the cable issue. If you have spare cable, try to replace it.
Just a quick update, I have now installed the WIC-2T and new cables. I have connected both lines, one 2Mbit to internet line and one 2Mbit point to point. The internet line is showing no errors on the interface whilst the point to point is still showing thousands within seconds of clearing the counters.
Attached is the output of a sh int s0
Could someone possibly just scan my configs please just to confirm I have no major blunder in there.
This is the router with the problem:
version 12.3
service password-encryption
hostname Tockwith
boot-start-marker
boot-end-marker
enable secret 5 ************
mmi polling-interval 60
no mmi auto-configure
no mmi pvc
mmi snmp-timeout 180
no aaa new-model
ip subnet-zero
ip cef
ip audit po max-events 100
no ip domain lookup
ip name-server 158.152.1.58
ip name-server 158.152.1.43
username ******* privilege 15 password 7 **********
interface FastEthernet0
ip address 10.106.11.1 255.255.255.0
ip nat inside
speed auto
no cdp enable
interface Serial0
ip unnumbered FastEthernet0
no cdp enable
interface Serial1
ip address xxx.xxx.xxx.xxx 255.255.255.240
ip nat outside
encapsulation ppp
ip nat inside source list 1 interface Serial1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 Serial1 permanent
ip route 10.106.10.0 255.255.255.0 Serial0 permanent
ip http server
ip http authentication local
no ip http secure-server
access-list 1 remark INSIDE_IF=FastEthernet0
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.106.11.0 0.0.0.255
no cdp run
banner motd ^CC
Demon Internet Gateway
^C
line con 0
exec-timeout 5 0
password 7 xxxxxxxxxxxxx
line aux 0
line vty 0 4
privilege level 15
login local
transport input telnet
end
This is the other end of the point to point:
version 12.4
hostname Eccles
boot-start-marker
boot-end-marker
logging buffered 51200 warnings
no aaa new-model
resource policy
no mmi pvc
ip subnet-zero
ip cef
no ip dhcp use vrf connected
ip domain name nowhere
username xxxxxx privilege 15 secret 5 xxxxxxx
interface FastEthernet0/0
description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$
ip address 10.106.10.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet0/1
ip address 172.22.16.1 255.255.255.0
duplex auto
speed auto
interface Serial0/0/0
ip unnumbered FastEthernet0/0
ip classless
ip route 0.0.0.0 0.0.0.0 172.22.16.10
ip route 10.106.11.0 255.255.255.0 Serial0/0/0
ip http server
ip http timeout-policy idle 5 life 86400 requests 10000
no cdp run
control-plane
line con 0
login local
line aux 0
line vty 0 4
privilege level 15
login local
line vty 5 15
privilege level 15
login local
end
I will do the loopback tests as soon as I can put it in loopback mode.
TIA
