What IOS feature sets support Appletalk
k.rodger
I have heard that Cisco is no longer including Appletalk in their IOS releases. Do you know what routers and what IOS feature sets/versions still support appletalk?
ChrisCopley_2
Hi Chris,
The advance enterprize services supports appletalk routing in most of the platforms.
on some platforms like the 1800 series, the enterprise base or services support appletalk routing
Use the feature navigator to identify whether a particular feature is supported with the IOS
http://tools.cisco.com/ITDIT/CFN/jsp/index.jsp
HTH, rate if it does
Narayan
Thanks Narayan - this is exactly what I was looking for!
