Service-Policy Input <PolicyName> does not register on the interface
monty.shen
mls qos map policed-dscp  22 30 to 14
mls qos map policed-dscp  26 to 30
mls qos map cos-dscp 0 8 22 30 34 46 48 56
mls qos map ip-prec-dscp 0 8 22 30 34 46 48 56
mls qos
class-map match-all ControlTraffic
  match access-group 102
  match ip dscp af31
  match ip precedence 3
class-map match-all VoiceTraffic
  match access-group 100
  match ip dscp ef
  match ip precedence 5
class-map match-all VideoTraffic
  match access-group 101
  match ip dscp af33
class-map match-all CriticalTraffic
  match access-group 103
  match ip dscp af23
  match ip precedence 2
policy-map Enterprise_QoS
description Enterprise Traffic Policy
class VoiceTraffic
   set ip dscp ef
  police 5000000 65536 exceed-action policed-dscp-transmit
class VideoTraffic
   set ip dscp af33
  police 2000000 65536 exceed-action policed-dscp-transmit
class ControlTraffic
   set ip dscp af31
  police 1000000 65536 exceed-action policed-dscp-transmit
class CriticalTraffic
   set ip dscp af23
interface GigabitEthernet1/0/24
switchport trunk allowed vlan 101-110,150
switchport mode trunk
__________________________________________________
When I run:
1. Conf t
2. Int GI1/0/24
3. Service-Policy Input Enterprise_QoS
The interface configuration does not change.  I cannot apply the service-policy to any interface.  This is a 3750 running 15.0(1)SE.
What is blocking the service policy from applying to the interface?
chris.macleod
Is there anything logged to say the command was rejected? I had a similar issue and I could see a rejection notice when I checked the logs (show logging).
What iOS feature set do you have installed? It may not support your exceed-action statement inbound on an interface.
Chris
There are no rejection notices in the logs.
I'm running the IPBase feature set.
I configured another Policy map without the policing statements
policy-map Enterprise-QoS
class VoiceTraffic
   set ip dscp ef
class VideoTraffic
   set ip dscp af33
   set ip dscp af31
   set ip dscp af23
and I still can't apply the service-policy to any interface
I just ran into the same issue, after configuring the service-policy on an interface, there is no error, but the command isn't applied to the interface.
The cause of this is the match-all or match-any statement in the class-map. if you configure the class-map like "class-map VoiceTraffic" it works fine.
This means that you're unable to allocate multiple access-list to the class-map, and thus need to reorganize your access-lists
