service-policy output issue
Angelo ANELLO
Hi Guys,  we have recently applied some QoS on our remote routers in a bid to improve performance and connectivity, however, every so often and randomly, the "service-poicy output policy-map" command is automatically removed from the WAN interface and we are not sure why.  we then have to reapply the policy in order to have it available again.  this happens to infrequently and on different devices for us to fidn a root cause.  The routers are model 881 and run firmware from ver 12.2 - 12.4.
Here is our current policy on the remote routers:
class-map match-any Citrix
match access-group name Citrix-ACL
policy-map WAN
class Citrix
  priority percent 80
  set dscp af41
class class-default
  bandwidth remaining percent 100
  random-detect
policy-map Global
class class-default
  shape average ##4096000## (value based on link speed)
  service-policy WAN
ip access-list extended Citrix-ACL
permit tcp any 192.168.1.0 0.0.0.255 eq 1494
permit udp any 192.168.1.0 0.0.0.255 eq 2598
int WAN
   service-policy output Global  (THIS IS THE COMMAND THAT KEEPS DROPPING OFF)
Any help is appreciated
Disclaimer
The  Author of this posting offers the information contained within this  posting without consideration and with the reader's understanding that  there's no implied or expressed suitability or fitness for any purpose.  Information provided is for informational purposes only and should not  be construed as rendering professional advice of any kind. Usage of this  posting's information is solely at reader's own risk.
Liability Disclaimer
In  no event shall Author be liable for any damages whatsoever (including,  without limitation, damages for loss of use, data or profit) arising out  of the use or inability to use the posting's information even if Author  has been advised of the possibility of such damage.
Posting
I don't have a specific bug or release note, but like Paolo, often issues like this are resolved in later IOSs.  BTW, this doesn't mean you need a version upgrade, for example, to upgrade from 12.2 to 12.4, sometimes moving to the latest patch release or newer point release will solve the problem.
As a generalization, the older IOS versions (12.2?) that supported mainline GD tagged releases, choosing the last GD tagged release is often a good bet.
paolo bevilacqua
Update IOS.
i had assumed this may be the case but can you provide any supporting documentation or link to some so that i can use it to proceed with upgrading the devices?
Disclaimer
Posting
i will try this and continue to monitor the routers for any further issues.
once confirmed i can close this request.
