Setting MTU on a 2851 serial I/F
mitchell.smith
Using WIC-1DSU-T1V2, is the MTU fixed or configurable? I cant find commands regarding this. Thanks, Mitchell
sourabhagarwal
Level 4
Level 4
To set the maximum transmission unit (MTU) size of IP packets sent on an interface, use the ip mtu interface configuration command. To restore the default MTU size, use the no form of this command.
ip mtu bytes
no ip mtu
you can go into interface config mode under the interface whose MTU you want to configure and try above commands. If it allows you to configure, it means you can set MTU otherwise not.
hope it helps ... rate if it does ...
sourabhagarwal
Level 4
Level 4
ip mtu bytes
no ip mtu
What is the difference of the MTU value under
"sh int fa 0/0" and "sh ip int fa0/0"?
Tx
Jaya
