Setting up ARIN network range on a router. BGP setup and how do I use my IPs?
badassmexican
I'm very new to Cisco routing.  I have a 7100 series router and a new ISP that will advertise our IP block.
I'm trying to figure out how to configure the router to allow us to use the IPs from our block.  Any pointers on what I'm missing would be greatly appreciated.  I'm having lots of fun with this router.
I was able to figure out how to get the router setup and now I have internet and DHCP working.
It has two ports which I assigned with the IP provided by my ISP and an internal IP.
I added my ISP gateway as a neighbor in my BGP settings:
neighbor 33.88.245.169 remote-as 174
I also added a route to my ISPs gateway and the Internet started working:
ip route 0.0.0.0 0.0.0.0 38.88.245.169
I also created a new access list 1.  4 was already there so I'm thinking maybe I should not have created a new one and just added to access list 4.
I bolded the things I've added to the configuration.  The rest was already there.  I think this router was already working but with a different ISP.
Router#show running-config
Building configuration...
Current configuration : 3151 bytes
version 12.1
no service single-slot-reload-enable
service timestamps debug uptime
service timestamps log uptime
hostname Router
logging rate-limit console 10 except errors
ip subnet-zero
no ip finger
no ip domain-lookup
ip dhcp excluded-address 192.168.250.0 192.168.250.6
ip dhcp pool Main-DHCP
network 192.168.250.0 255.255.255.0
default-router 192.168.250.1
dns-server 66.28.0.45
call rsvp-sync
interface FastEthernet0/0
ip address 192.168.250.1 255.255.255.0
ip nat inside
duplex auto
speed auto
interface FastEthernet0/1
description Uplink
ip address 38.88.245.170 255.255.255.248
ip nat outside
duplex full
speed 100
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
bgp log-neighbor-changes
network 207.182.96.0
network 207.182.97.0
network 207.182.98.0
network 207.182.99.0
network 207.182.100.0
network 207.182.104.0
network 207.182.105.0
ip nat inside source list 1 interface FastEthernet0/1 overload
ip nat inside source list 4 interface FastEthernet0/1 overload
ip classless
ip route 0.0.0.0 0.0.0.0 FastEthernet0/1
ip route 207.182.96.0 255.255.255.0 FastEthernet0/0
ip route 207.182.97.0 255.255.255.0 FastEthernet0/0
ip route 207.182.98.0 255.255.255.0 FastEthernet0/0
ip route 207.182.98.0 255.255.255.128 FastEthernet0/0
ip route 207.182.99.0 255.255.255.0 FastEthernet0/0
ip route 207.182.100.0 255.255.255.0 FastEthernet0/0
ip route 207.182.101.0 255.255.255.0 FastEthernet0/0
ip route 207.182.102.0 255.255.255.0 FastEthernet0/0
ip route 207.182.103.0 255.255.255.0 FastEthernet0/0
ip route 207.182.104.0 255.255.255.0 FastEthernet0/0
ip route 207.182.105.0 255.255.255.0 FastEthernet0/0
no ip http server
ip prefix-list USCOLO_out seq 10 permit 207.182.96.0/24
ip prefix-list USCOLO_out seq 11 permit 207.182.96.0/19
ip prefix-list USCOLO_out seq 20 permit 207.182.97.0/24
ip prefix-list USCOLO_out seq 30 permit 207.182.98.0/24
ip prefix-list USCOLO_out seq 40 permit 207.182.99.0/24
ip prefix-list USCOLO_out seq 41 permit 207.182.100.0/24
ip prefix-list USCOLO_out seq 42 permit 207.182.104.0/24
ip prefix-list USCOLO_out seq 45 permit 207.182.105.0/24
ip prefix-list USCOLO_out seq 99 deny 0.0.0.0/0
ip prefix-list default seq 5 permit 0.0.0.0/0
logging facility local0
logging source-interface FastEthernet0/0
access-list 1 permit 192.168.250.0 0.0.0.255
access-list 4 permit 207.182.105.0
access-list 4 permit 207.182.104.0
access-list 4 permit 207.182.97.0
access-list 4 permit 207.182.96.0
access-list 4 permit 207.182.99.0
access-list 4 permit 207.182.98.0
access-list 4 permit 207.182.100.0
route-map USCOLO permit 10
match as-path 1
set local-preference 103
route-map USCOLO_out permit 10
match ip address prefix-list USCOLO_out
line con 0
transport input none
line aux 0
line vty 0 4
login
line vty 5 15
login
end
39 Replies 39
Hello
so then please summerise your requirements regards your network and we can assist you with the getting the router into a running state
Kind Regards
Paul
Thanks for the help.
Currently we have:
Old ISP -> Cisco 1900 series -> Sonicwall (DHCP) -> Switch -> LAN
What we need now is to replace our old ISP with the new one that will allow us to use the IP's we own on systems in our LAN.  Systems that don't need a static IP could just use DHCP behind one IP for the whole network.  I'm not sure which of these two layouts would work best.
We want to be able to use all the IPs we own.
AS Number/Range:  6551
AS Handle:  AS6551
Net Range:  207.182.96.0 - 207.182.127.255
CIDR:  207.182.96.0/19
                                           static IP systems
New ISP -> Cisco 7100 series -> switch <
                                           SonicWall -> DHCP LAN
or
        static IP systems
New ISP -> Cisco 7100 series -> switch -> SonicWall <
                                                       DHCP LAN
The SonicWall is at end of life and I'm looking for a replacement.  It's doing its job of being a firewall and blocking and forwarding ports, etc.  But the service that does the reporting and content/site filtering has expired.  So I'm looking into a new model or something better.  Can the 7100 do the basic firewall stuff since it's a router?
Hello
AS Handle:  AS6551
Not sure i understand the above ? -  Are you saying the above  /19 public ip address range has been allocated your company?
and you are wanting or running this address range internally on your lan devices?
Do you have a running config of your exiting router that this new router is going to replace.
Kind Regards
Paul
Correct, we have the /19 allocated to us.  We want to be able to use them.  Of course in the safest way possible to protect the LAN.  So they could be in a separate LAN that we remote into.  But we want it all behind this router if possible.
I do not have a running config of the router we're replacing.  But it doesn't do anything with our /19 range.  That ISP didn't offer the advertising or BGP feature.
On the new Router and ISP:
My DHCP IPs get on the internet no problem.
I'm finally able to use IPs in the 207.182.100.0 range.  I couldn't get on the internet with any of the /19 IPs but I added this line to the config and it worked.
access-list 4 permit 207.182.100.0 0.0.0.255
I still don't see that IP when I do a Who AM I IP look up.  I get:
38.88.245.170
Here's my current running config:
Current configuration : 3551 bytes
version 12.1
hostname Router
ip subnet-zero
no ip finger
no ip domain-lookup
call rsvp-sync
description 700 S flower
ip address 207.182.100.1 255.255.255.0 secondary
ip address 207.182.97.4 255.255.255.0 secondary
ip address 207.182.96.18 255.255.255.240 secondary
ip address 207.182.96.34 255.255.255.240 secondary
ip address 207.182.96.61 255.255.255.240 secondary
ip address 207.182.96.7 255.255.255.240 secondary
ip address 207.182.98.1 255.255.255.0 secondary
ip nat inside
duplex auto
speed auto
description USCOLO-Uplink
ip nat outside
duplex full
speed 100
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
ip classless
no ip http server
match as-path 1
line con 0
line aux 0
line vty 0 4
login
line vty 5 15
login
end
I hope I'm using the right terminology.  I am very new to this.  Basically I just want to be able to assign a static IP to a machine and have that IP be visible to the world.
Hello
Not to worry , I think I am not asking the right questions , as I am still a a bit confused, If i have this correct your present situation is this:
You have an existing network up and running on a router you dont have access to via the old ISP which you are wanting to discontinue using.
You also have another router with old configuration on it that you are trying to connect to the new ISP to include the network ip range and bgp ASN details you posted previously.
Now this ip range, it seems a lot of public ip address (8000 in fact) to be assigned just to one company so I am wondering if this is just the ISP's network that they are adverting and not what you have actually been allocated?
Kind Regards
Paul
Hi Paul,
Thanks for helping me figure this out.  You do have our present situation correct.  We want to get rid of the old ISP and their router and use the new ISP with the second router that has old configuration.  I'm not really sure if it was configured correctly originally.   We probably don't need the subnetted 207.182.96.xxx networks.  Unless there is some benefit to that.
We do own all those IPs.  I log into the ARIN site with our credentials and I get that info straight from them.  Since we own them we want to figure out how to use them when needed.  I'm sure we'll only be using a few at a time and not all of them.
I've been trying to figure it out and now I can get internet through DHCP and use the IPs in the ranges of the IPs on my f0/0 port.  I noticed I can use the IPs assigned to f0/0 as gateways as well as the gateway provided by the ISP.  They both seem to work to get me online when I use the IPs we own.   But these IPs are only visible behind the router.  I see the ISP provided IP when I do a "Who Am I" look up instead of the static IP I set on the client.   I was hoping a 1-to-1 nat for our ARIN assigned subnet would get the IPs visible to the outside but I just started trying to figure that out.
Hellosh
Okay ,  Can you post the following please:
sh ip bgp summary
sh ip route bgp
sh ip route
sh ip int brief.
Kind Regards
Paul
Unfortunately I don't have access to the router today.  I'll get that info when I'm back at the office tomorrow.
I do have the current running config though.
version 12.1
hostname Router
ip subnet-zero
no ip finger
no ip domain-lookup
call rsvp-sync
ip nat inside
duplex auto
speed auto
ip nat outside
duplex full
speed 100
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
ip classless
no ip http server
match as-path 1
line con 0
line aux 0
line vty 0 4
login
line vty 5 15
login
end
Hello
Attached is a basic configuration to obtain bgp peering with your isp and to allow Network Address Translation with a /24 ip range from your public address allocation. NAT will match each individual internal ip address via it host portion (inside local) with a individual public ip address(inside global) host portion:
Example:
192.168.250.2 <-->  207.182.96.2
192.168.250.3 <-->  207.182.96.3
etc..
Also applied is some IOS security just incase you would like to implement it as you didn't mention any existence of any FW in your topology.
I have made the assumption you are receiving a default route from you ISP via bgp and as such filtered ingress on that default.
If you are experiencing any connection issue with the IOS security( cbac/acl) please remove the ACLs  from your wan interface and change accordingly.
Kind Regards
Paul
Hi Paul, Here's what those commands returned before applying your recommended settings. I'm doing that next.
Router#sh ip bgp summary
BGP router identifier 192.168.250.1, local AS number 6551
BGP table version is 18, main routing table version 18
7 network entries and 7 paths using 931 bytes of memory
1 BGP path attribute entries using 60 bytes of memory
0 BGP route-map cache entries using 0 bytes of memory
0 BGP filter-list cache entries using 0 bytes of memory
BGP activity 8/1 prefixes, 12/5 paths, scan interval 15 secs
Neighbor V AS MsgRcvd MsgSent TblVer InQ OutQ Up/Down State/PfxRcd
33.88.245.169 4 174 0 0 0 0 0 never Idle
Router#sh ip route bgp
Router#
Router#sh ip route
Codes: C - connected, S - static, I - IGRP, R - RIP, M - mobile, B - BGP
D - EIGRP, EX - EIGRP external, O - OSPF, IA - OSPF inter area
N1 - OSPF NSSA external type 1, N2 - OSPF NSSA external type 2
E1 - OSPF external type 1, E2 - OSPF external type 2, E - EGP
i - IS-IS, L1 - IS-IS level-1, L2 - IS-IS level-2, ia - IS-IS inter area
* - candidate default, U - per-user static route, o - ODR
P - periodic downloaded static route
Gateway of last resort is 0.0.0.0 to network 0.0.0.0
S 207.182.101.0/24 is directly connected, FastEthernet0/0
C 207.182.100.0/24 is directly connected, FastEthernet0/0
S 207.182.103.0/24 is directly connected, FastEthernet0/0
S 207.182.102.0/24 is directly connected, FastEthernet0/0
C 207.182.97.0/24 is directly connected, FastEthernet0/0
38.0.0.0/29 is subnetted, 1 subnets
C 38.88.245.168 is directly connected, FastEthernet0/1
207.182.96.0/24 is variably subnetted, 5 subnets, 2 masks
C 207.182.96.16/28 is directly connected, FastEthernet0/0
C 207.182.96.0/28 is directly connected, FastEthernet0/0
S 207.182.96.0/24 is directly connected, FastEthernet0/0
C 207.182.96.48/28 is directly connected, FastEthernet0/0
C 207.182.96.32/28 is directly connected, FastEthernet0/0
S 207.182.99.0/24 is directly connected, FastEthernet0/0
207.182.98.0/24 is variably subnetted, 2 subnets, 2 masks
S 207.182.98.0/25 is directly connected, FastEthernet0/0
C 207.182.98.0/24 is directly connected, FastEthernet0/0
C 192.168.250.0/24 is directly connected, FastEthernet0/0
S 207.182.105.0/24 is directly connected, FastEthernet0/0
S 207.182.104.0/24 is directly connected, FastEthernet0/0
S* 0.0.0.0/0 is directly connected, FastEthernet0/1
Router#
Router#sh ip int brief
Interface IP-Address OK? Method Status Protol
FastEthernet0/0 192.168.250.1 YES NVRAM up up
FastEthernet0/1 38.88.245.170 YES NVRAM up up
Serial1/0 unassigned YES NVRAM administratively down down
Hi Paul,
I seem to be missing some of the commands.  Could it be my router os is too old?  These commands gave me issues:
*security authentication failure rate 10 log
*security passwords min-length 6
(Security wasn't available)
*login block-for 10 attempts 2 within 5
(login command not available)
*no ipv6 cef
(no ipv6)
*no cdp log mismatch duplex
(no log only advertise-v2, holdtime, timer and run)
*no ip http secure-server
(no secure-server only access-class, authentication, path, port, server)
*crypto key generate rsa label LOCAL general-keys modulus 2048
(no crypto)
*ip ssh version 2
*ip ssh authentication-retries 3
(no ssh)
*ip inspect audit-trail
*ip inspect udp idle-time 1800
*ip inspect dns-timeout 7
*ip inspect tcp idle-time 14400
*ip inspect name CBAC ftp timeout 3600
*ip inspect name CBAC http timeout 3600
*ip inspect name CBAC rcmd timeout 3600
*ip inspect name CBAC realaudio timeout 3600
*ip inspect name CBAC smtp timeout 3600
*ip inspect name CBAC tftp timeout 30
*ip inspect name CBAC udp timeout 15
*ip inspect name CBAC tcp timeout 3600
(no inspect)
*ip inspect CBAC out
(no inspect in f0/1)
*ip nat inside source route-map LAN pool LAN-POOL reversible
(no reversible, only overload or <cr> so I tried it)
*transport input ssh
(no ssh only all, none, pad, telnet, v120)
Here's what I was able to add of the config file:
Current configuration : 2347 bytes
version 12.1
service tcp-keepalives-in
service tcp-keepalives-out
service timestamps debug datetime msec localtime show-timezone
service timestamps log datetime msec localtime show-timezone
service password-encryption
service sequence-numbers
hostname Router
logging console critical
aaa new-model
aaa authentication login LOCAL local
aaa authorization console
ip subnet-zero
no ip source-route
no ip gratuitous-arps
no ip icmp rate-limit unreachable
ip cef
no ip finger
ip tcp synwait-time 5
no ip domain-lookup
no ip bootp server
call rsvp-sync
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
shutdown
duplex auto
speed auto
ip address 33.88.245.170 255.255.255.248
ip access-group cbac in
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
shutdown
duplex auto
speed auto
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
no synchronization
neighbor 33.88.245.169 route-map allowdefault in
neighbor 33.88.245.169 filter-list 5 out
no auto-summary
ip nat pool LAN-POOL 207.182.96.1 207.182.96.254 prefix-length 24 type match-host
ip nat inside source route-map LAN pool LAN-POOL overload
ip classless
no ip http server
ip as-path access-list 5 permit ^$
ip prefix-list 1 seq 5 permit 0.0.0.0/0
ip access-list extended cbac
permit icmp any any echo-reply
permit tcp any any eq bgp
permit udp any any eq bootpc
permit udp any any eq snmp
permit tcp any any established
deny ip any any
logging trap debugging
logging facility local2
access-list 10 permit 192.168.250.0 0.0.0.255
no cdp run
route-map allowdefault permit 10
match ip address prefix-list 1
route-map LAN permit 10
match ip address 10
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
login authentication LOCAL
line aux 0
privilege level 15
logging synchronous
transport output telnet
line vty 0 4
line vty 5 15
end
secret
*username commsadmin privilege 15 secret
Hello
Yes most probably down to ios restriction in any case
no shutdown
no ip access-group cbac in
no shutdown
Then test....
Kind Regards
Paul
I fixed the silly mistakes I had on my ports.  I don't seem to have the "reverse" option on my nat rules.  Would that be causing me not being able to ping my gateway?
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
duplex auto
speed auto
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex full
speed 100
Current configuration : 2307 bytes
version 12.1
hostname Router
aaa new-model
ip subnet-zero
no ip source-route
ip cef
no ip finger
no ip domain-lookup
no ip bootp server
call rsvp-sync
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat inside
duplex auto
speed auto
no ip redirects
no ip unreachables
no ip proxy-arp
ip nat outside
duplex full
speed 100
interface Serial1/0
no ip address
shutdown
framing c-bit
cablelength 10
dsu bandwidth 44210
router bgp 6551
no synchronization
no auto-summary
ip nat inside source list 10 interface FastEthernet0/1 overload
ip classless
no ip http server
deny   ip any any
no cdp run
match ip address 10
line con 0
exec-timeout 0 0
privilege level 15
logging synchronous
line aux 0
privilege level 15
logging synchronous
line vty 0 4
line vty 5 15
end
Hello
No it should not negate pinging you gateway, however as I stated i assumed you are receiving a default route from your ISP 33.88.245.169
Can you post:
sh ip route
sh ip bgp sum
Kind Regards
Paul
